Old 06-01-2020, 04:54 PM
Mars's Avatar
Mars Mars is offline
Hate to ask..
81 j10 727 with low range. Have an output seal leaking. Trying to order parts, I'm a couple states away from it so can can't just crawl under it. What TC should be under there?
Wannabe Fabricator
Grumpy on a good day.
Old 06-02-2020, 10:00 PM
Most likely a NP208
-Jonny B.
AMC 401 - Pro-Flo 4 EFI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 06-03-2020, 08:53 PM
Mars's Avatar
Thanks man
Wannabe Fabricator
Old 06-04-2020, 05:09 AM
It could also be a NP219. Can you share a picture of the flag shifter handle? It will have the shift pattern on it.
Old 06-05-2020, 08:30 PM
Did the NP219 come with factory manual locking hubs?
-Jonny B.
Old 06-05-2020, 10:36 PM
Mars's Avatar
Wannabe Fabricator
Old 06-06-2020, 11:08 PM
DarkMonohue's Avatar
Shakes hands with danger
Agreed, a part time setup from that era should have an NP208 behind a 727. My '85 J20 does and the parts catalog indicates the same thing for your '81 J10.
Jeep part numbers for output shaft seals (where the driveshaft yokes exit the transfer case) are 83504434 for the front and 83502508 for the rear. Those cross-reference at RockAuto to SKF numbers 18771 front and 18662 (or Timken/National 3946) rear.
Old 06-08-2020, 06:58 PM
Mars's Avatar
Thank you gents. I'm still pretty far away from it. I'll order those seals and hopefully they are waiting for me when I get some home time.
Wannabe Fabricator
Don't you just hate it when folks dont fix things right, the first time? Texafornian General FSJ Discussion 6 07-04-2014 04:36 PM
Man, I hate you people.... Revhendo General FSJ Discussion 19 10-04-2011 01:16 PM
I really HATE....drum brakes!! JeepsAndGuns General FSJ Discussion 12 12-02-2008 05:19 PM
Jeep Hate runs deep (long) ne715 General FSJ Discussion 25 04-13-2008 08:28 AM
