Old 12-23-2008, 08:07 PM
JEEPS@HORSES's Avatar
JEEPS@HORSES JEEPS@HORSES is offline
power train swap questions need advice
I have a 78 cherokee chief WT 360amc th400 q-trac, I have been putting together gm drive train 350 (82) dana 300 stock. I will buy novak motor mounts and th4oo to dana 300 adapter. my first question is
should i look for the th400 with the short 4x4 tail or would the regular length tail be ok. secondly i ve herd of engine offset to one side or the other, is this for the drivetrain or engine clearance reasons.
thanks
Old 12-23-2008, 08:25 PM
jeepjerry's Avatar
What is wrong with your 360? I would run an amc 360 all day long over a 350. Cam it and fuel inject it and you would be well off!! You've already got a good trans unless you want overdrive.
1977 J-20, 4bbl AMC 360/t-18,33"s.
1976 CJ-5, Healthy AMC 360/t-18, 6" lift, 35"s.
1972 Javelin SST, mild AMC 360. Under cunstruction.
AMC ya!!
Alfano Performance
Kenosha, WI 53142
Old 12-23-2008, 08:27 PM
Dmntxn77's Avatar
Dmntxn77 Dmntxn77 is offline
Hey watch this...
Sorry, cant help with your swap questions, but.....
Welcome from a fairly local member... Assuming you wheel it, we will have to make a trip to the river when I get back down there...
Old 12-23-2008, 08:52 PM
I have looked into a 360 rebuild but the price of amc parts over gm is pushing me.
dmntxn looking foward to a canadian river run. my friend runs cj2 and we love the fun, load up the cooler and the old ladies and kids and spend the day.
Old 12-23-2008, 09:19 PM
jeepjerry's Avatar
Yeah the cost of rebuilding anything is expensive, but AMC's are a bit more. The prices of aftermarket AMC parts is going down though. Im just a guy who loves to keep the unique AMC power in the jeeps. Anyway, do what it takes to get your FSJ going.
AMC ya!!
Alfano Performance
Kenosha, WI 53142
Old 12-23-2008, 11:14 PM
crazydog's Avatar
crazydog crazydog is offline
Not sure of anyone to recommend up in Amarillo, but if you don't mind heading to Lubbock, check with Tiner Machine in Lubbock. When I talked to them last year about rebuilding my 401 short block, they had built some AMC's fairly recently, and the prices seemed okay to me. There used to be a guy in Dimmit that used to drag race with my dad in the late 60's and early 70's. He raced a AMX and had a machine shop. I really wanted to get him to build my engine, but last I heard, he had retired and moved to Plainview. Come to think of it you might check and see if Carrol Caudel (sp?) still builds engines in Amarillo.
Good luck with whatever direction you decide to take your build.
1967 J3500 - Making plans
Old 12-26-2008, 10:13 AM
Thanks everyone for your advice, this gives me alot to think about.
