Old 01-01-2019, 06:52 PM
His-N-Hers Woodies His-N-Hers Woodies is offline
Rear mount XJ gas tank (LS Swap) write up
I decided to use a later model XJ tank for my grand waggy LS swap. The 19 gallon tank is a good fit in the spare tire location. The problem is the filter/regulator needs to be bypassed so it can deliver the required pressue. My cost was about $50 including a new universal level sending unit.
Added a return by drilling and tapping for a fitting.
Used this $35 sending unit.
Drilled and tapped the 5 holes which ARE NOT equally spaced apart
Remove the filter/regulator. Run a line so the pump discharges through the hole where the filter/regulator was. Us an external filter of your choice.
A 1/4 pipe coupling fits nicely in the hole. I secured mine with JB weld. I couldn't find a JIC/NPT elbow locally so I cobbled one together from stuff I did have.
Plumbed up the pump and slid it back into the module housing
I'm using a spin-on element
Fuel pressure is what the dr ordered and no leaks.
Fabricated some brackets to use the XJ hangers. Trimmed the original hoses and plumbed them up the the fill necks.
Old 05-29-2019, 07:23 AM
81jseries's Avatar
81jseries 81jseries is offline
Thank you for posting this! I picked up a 97 XJ tank this past weekend for my sniper efi install because of this post. I'm hoping to get my stock 1967 fuel gauge to work, Is there a reason you used the aftermarket sending unit rather than the stock XJ sending unit?
Old 06-02-2019, 06:52 AM
JeepsAndGuns's Avatar
I put the same late model XJ plastic tank in my 79 a few years ago. I had a local metal shop bend me a 1/2 in thick steel plate to match the contour of the XJ tank and then used that to mount the tank. I can support the whole back of the jeep on that skidplate.
For the sender, I took the bottom half of the XJ sender, and combined it with the top half of a WJ sender. The WJ's use a very similar sending unit with the exception of that they use a external regulator (built into the fuel filter) so it has a normal feed and return fitting on it. However the WJ tank is not as deep as the XJ tank. So I combined the two.
For some reason I never took pictures when I did all this years ago.
Old 06-07-2019, 09:08 PM
I like it.
I may wind up sacrificing my spare tire to do something like this. Right now I have TBI & a TBI pump in the stock tank, but I picked up an MPFI manifold so... this might be happening sooner than I care to think about
Rear Axel Swap Info Needed anderob General FSJ Tech 3 06-28-2008 09:01 PM
plastic fuel tank swap dilbertgonebad General FSJ Tech 4 08-24-2005 02:30 AM
(TOM)How to swap a Razor Grille onto a late model Waggy or Chero. Sitting Bull Body 28 03-06-2003 05:02 PM
How to swap a Razor Grille onto a late model Waggy or Chero. Sitting Bull Topic Of The Month 26 03-04-2003 03:50 AM
rear fuel tank retro-ift River Beast Other 6 09-08-2000 10:12 PM
