Old 09-21-2012, 03:31 PM
fireman239's Avatar
fireman239 fireman239 is offline
TRANNY SWAP!!! 84 AUTO WAGGY TO AX15
anyone ever done this? i really want a manual transmission and heard this will be a good option? anybody have any tricks? can i use the 4.0 bell housing or do i need to find a bell housing for a manual trans 360? fly wheel and pressure plate options? and hydraulic clutch solutions. any input would be greatly appreciated. on a budget so used or reman parts would be awesome if applicable
Old 09-21-2012, 07:10 PM
Yagan's Avatar
Yagan Yagan is offline
hey fireman 239
here is a link that may answer your q's...
http://www.ifsja.org/forums/vb/showt...ht=recycledj10
good luck! This swap interests me also,,,,but then i just keep thinking...how much do I really want an extra cog? when i think of the stout 727 i always move on to diferent ideas
Baby Blue - 81 Cherokee S 4 dr
Twin Trans Coolers no longer in radiator flow path
Baked Copper Coated B&M Deep Trans Pan
Custom Cooler ducting and braided lines
79 American Racing Cast Alloy rims
Monroe Air, Rear Reece Hitch, Front Hidden Reece Hitch,Dual Batts, re-con’d Alt, Front Bench Seat
My rig is ubber hot, my FSJ is a chick magnet
Old 09-21-2012, 07:44 PM
Kris's Avatar
Kris Kris is offline
Links in my sig.
k.
89 Waggy
AX-15 swap info threads...
http://www.ifsja.org/forums/vb/showthread.php?t=83102
http://www.ifsja.org/forums/vb/showthread.php?t=97262
http://www.ifsja.org/forums/vb/showthread.php?t=104163
Theres more but that should get you started
Originally Posted by JeepinPete
-If it wasn't for bad luck, you wouldn't have any luck at all-
Old 09-21-2012, 11:32 PM
Too bad you aren't close to Seattle. I have an AX-15 (external slave style, but missing some bell bolts and the throwout arm and slave) and 23 spline NP231 for sale along with a 6 cyl flywheel (needs balanced to the 360 then you can use the better XJ style starter) I even have pedals
Old 09-22-2012, 11:02 AM
fireman239's Avatar
thank you so much that was very helpful. any tips for the hydraulic clutch setup?
Old 09-22-2012, 11:18 AM
No real info but for a hyd clutch I would go with an external slave like on CJ's. In my experience with hyd clutches is that the slave is the weak maint prone item in the system so an external slave makes life a lot easier for maint. Later when you do your scheduled brake flushes don't forget to do a clutch flush too.
Old 09-22-2012, 02:34 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
You really only get one choice with the AX-15/NV3550 clutch...the factory setup. There is an external and an internal style. Definitely go with the external style (dependent on year and bellhousing). It is not technically serviceable...but you can flush it and bleed it backward. It's a bit of a pain, but doable.
aa
Old 09-22-2012, 07:48 PM
fireman239's Avatar
so if i have a good donor. all i should need is for the flywheel to be balanced. and stock replacement parts as needed
Old 09-22-2012, 08:47 PM
Cecil14's Avatar
Yup.
aa
Old 09-22-2012, 08:57 PM
fireman239's Avatar
awesome. thank you very much. i will post progress and photos as i go
Tranny swap ONLY with 360 interceptor General FSJ Tech 3 08-06-2009 01:57 PM
auto to manual swap amc75matador General FSJ Tech 1 09-05-2006 07:36 PM
tranny swap WE B GPN General FSJ Tech 5 07-10-2004 02:37 PM
Planning an Engine/Tranny Swap into my Waggy..some questions of course!!!! BigDC General FSJ Tech 9 04-22-2004 12:47 AM
How to swap a Razor Grille onto a late model Waggy or Chero. Sitting Bull Topic Of The Month 26 03-04-2003 03:50 AM
