Old 01-19-2004, 04:00 PM
Kevin718 Kevin718 is offline
I have a 1991 GW, 360 with 727. I just replaced the transmission mount, and the sound of the GW has changed.
With old transmission mount:
Engine and transmission rocked back and forth when stopped. It was most noticable in drive. No noticable noise coming from the transmission.
With new transmission mount:
Engine and transmission do not rock back and forth, it seems very stable. But now there is a noise that seems to be coming from the bell housing area, where the transmission meets the engine.
Was the excessive rocking, and now the new noise caused by some transmission problem?
Thanks for your help.
1991 Grand Wagoneer
360/2150/727/NP229/3.31
Old 01-19-2004, 04:27 PM
Ralph's Avatar
Ralph Ralph is offline
Third Member
The busted tranny mount, which previously allowed the engine and tranny to move quite a bit, could have cause excess wear of internal parts in the transmission that resulted in excessive endplay or wear in the bearings and bushings that keep the internal components revolving smoothly. Now that you've put in a more rigid mount, the endplay or wear is more evident.
We did it to Japan. We can do it to it to Iran!
Old 01-23-2004, 06:29 AM
grimgaunt grimgaunt is offline
Location: close enuff to Denver, but far enuff from the people
plus the 727 has only 2 support bearings to begin with, as opposed to a REAL transmission such as the TH400 that has 3
Old 01-25-2004, 12:55 PM
Update - I just replaced the engine mounts yesterday. Both of the mounts were broken. Now, instead of just a different sound, there is a vibration that rattles the dash and the driver's side door (I have the door panel off). This vibration is present when idling in drive and during initial acceleration.
Any additional thoughts? Is it most likely the transmission, or the engine? Since it is smoother at higher speeds, I am thinking it is the transmission.
1991 Grand Wagoneer
Old 01-25-2004, 03:10 PM
FSJnovice FSJnovice is offline
Cracked flywheel?
Mike
88 GW stock
360/727/229
project
