07-22-2005, 05:30 AM
’91 GW transmission swap
I recently began contemplating installing an overdrive automatic to replace my TF727 and NP229 (driver’s side drop).
When brainstorming this task, a few questions come to mind:
1) I was intending to swap in a TH700R4 with NP208; what, when, and where was this combination available on GM products from which I can steal my parts?
2) When using the AMC motor to GM transmission adapter, along with the GM bell housing, can I anticipate any firewall clearance problems? Can I anticipate other undercarriage clearance problems when making this swap?
3) How much longer (dimensionally) is the proposed transmission/transfer case than the stock arrangement? How will this effect drive shaft lengths?
4) Will the stock u-joints bolt up to the NP208?
5) Will this swap affect cruise control operation/connection?
6) Can the TH700R4 be selected/shifted to lock out the overdrive for towing?
7) How to accommodate speedometer cable adaption?
8) How to accommodate the transmission cooler connection?
9) How to accommodate the original floor mounted low range shifter to the new parts?
10) How to accommodate the dash mounted 4x4 selector to the new parts?
11) Can I use some of the Chevy mounting brackets/parts to mount the parts into the Jeep? Which one’s?
12) How to accommodate the factory transmission shifter to the new transmission? How can the factory shifter be adapted to arrange selection and indication of overdrive or drive on the factory steering column shifter?
13) What vintage transmission and rebuild part considerations do I need to make when selecting/rebuilding the TH700R4?
What have I forgotten to consider?
As mentioned above, I was intending the TH700R4 with NP208 but would consider a Dodge NP241 with another transmission if the right combination can be identified to me and all the above questions can be answered.
Thanks in advance for any and all help.
07-22-2005, 05:41 AM
Are you planning an axle ratio swap also? If not an OD tranny will be useless in a stock geared 91 with the 2.73 or 3.31 gears(only stock gears avail from factory). These rigs are pretty much overdriven axle wise as is. Add an OD trans and in OD you'll be so low in the motors power band the trans will constantly be shifting itself back into high gear(3rd) anyway.
07-22-2005, 07:17 AM
I had heard that the Chrysler 518(A)??? is essentially a 727 with overdrive. The output yoke is longer...
07-22-2005, 07:52 AM
Gone. Not Forgotten.
the 518 is a 727 with a Overdrive bolted to the
back end. The issue is there are no AMC bolt pattern 518's,the OD unit is pretty long and the
valve body differences make it a non starter as
far as using the unit boted to the back of a AMC
727. I have a NOS 518 OD unit and a AMC 727 core
but have not had time to look try and see what
would all have to change to make it work but I don't think it is going to work without more time
and $'s than I want to spend.
I think a 700r4 with great after market support would
be the mos practical.
Mike D.
Home of ADHD project list
1977 J-10 Honcho 360-T15-D20
07-22-2005, 08:20 AM
If you have 3.31 gears, and are running stock tires, then adding a 700R4 will give you gearing very similar to what newer trucks are running. For example, I have a '01 Durango. It is running 265/70/16 tires, and 3.55 gears. Run the numbers, and it turns 1612RPM a @60mph. A Wagoneer with 3.31 gears, 235/70/15 tires, you would be turning 1672rpm @60mph. Whether the 360 has enough to push a Wagoneer and the speed in another question...
Pete
Isuzu 6BD1, NV4500, NP241
Thread Tools |
Display Modes |
