Old 02-16-2004, 12:05 AM
badaboom's Avatar
badaboom badaboom is offline
Question
What is the correct size bolt thread and type thread for the AMC V8 valve cover bolts?
1/4"-20 x 5/8" thread? If someone provided you the noted figures would this work for the AMC V8?
1981 Jeep J10 Laredo, 401-V8, 625 Carter, Lunati 262/268, Edelbrock Performer, MSD Ign., Hydroboost, Hyd. Clutch, Flow Cooler WP, Be Cool Aluminum Radiator, Doug Thorley, NV4500 5-Spd, NP-231D, 3.73 F/R Trac-Locs, Rustys 4" Lift, Vintage Red Metallic, Black Interior and 33X10.50X15 BFG, FiTech400 to come - IN PROCESS Bling Bling Cha-Ching
Old 02-16-2004, 12:51 AM
Quartermaster Quartermaster is offline
On the 1988 model year, they are 1/4-20. The length sounds like it would work depending on the thickness of the gasket.
1988 Grand Wagoneer (nude) 360 bored .03 over, Edelbrock performer intake/Carb/Cam, TFI upgrade, Thorley Ceramic coated headers, 3" High flow Cat, 70 series flowmaster, Espo springs (No lift) and air bags in the rear (for trailer towing), CS144 upgrade.
Old 02-16-2004, 01:44 AM
badaboom's Avatar
Quartermaster
Appreciate the info
Old 02-16-2004, 02:42 AM
Matt in AZ Matt in AZ is offline
I recall that was the size my 1976 360 used. I had it off often.
Old 02-16-2004, 06:25 AM
beloth's Avatar
beloth beloth is offline
i used the bolt package from the help! section that are made for transmission pan bolts and those worked fine and look great.
Robert
1966 wag "JENNY" w/1973 drivetrain
330K miles w/360 V8 2bbl (HEI installed ), flowmaster muffler
TH400 /Dana 20 transfer case D30 /D44 w/ 3.73's LT235/75/R15 AT tires. lift shackles in frt. 2 in lft; w/ TAD's Dozer bumpers! Cost $700 -now total cost=?
