Old 11-29-2010, 09:20 PM
Thumper168's Avatar
Thumper168 Thumper168 is offline
Running Issue
Ok guys, I took my 84 Wagon for its first ride today and everything went well for about 45 minutes, once it warmed up good it stalled and sputtered and lost power but it never actually died, It would drive fine up to a certain rmp and around 30 mph but once you cross that spot it sputtered like it was loosing fire. I have allready replaced the pick up coil and im leaning towad the firing coil, any ideas?? Once it cooled down it seemed to run fine again.
Old 11-29-2010, 09:53 PM
FSJ Guy FSJ Guy is offline
Since it won't go above a certain rpm, that sounds like either a bad float adjustment (if you still have a carb) or a clogged fuel filter in the tank or in the engine compartment (regardless of fuel delivery system).
When it cooled down, however, would it run well over 30 mph?
If the symptoms went away after cooling down, then ignore.
Ethan Brady
www.bigscaryjeep.com
Old 11-29-2010, 10:05 PM
Thumper168's Avatar
It ran fine after cooling down, it was running bad and I came to a car wash and the motor needed washing and it was running bad anyway not to mention I was only about a mile from the shop so I washed it, fired it up after and it ran just fine all the way to the shop. Tomorrow I plan to replace the igniton control module, the coil and a new fuel pump not to mention I need a new fuel sending unit so Ill check the screen and replace the inline filter as well. Anything else I need to replace or check?? Could it be vapor locking?
Old 11-29-2010, 10:14 PM
OK, it it truly ran better once cooled down, it's probably your ignition module. You can replace it with a (duh) replacement or wire up a GM 4 pin module to fire your ignition and gain some reliability, too.
Google will bring up several wiring diagrams. Just be sure to provide the module with a good heatsink and don't be stingy with the heatsink grease.
Ethan Brady
Old 11-29-2010, 10:20 PM
Thumper168's Avatar
Thanks for your thoughts! Im new to the FSJ scene so Im learning as I go!!!! I also want to avoid a few future problems by replacing a few of the 26 year old parts that I know will fail at just the right time when Im in BFE.
Old 11-29-2010, 10:54 PM
Some people report good results with a parts store replacement module. Others report that they poop out (sometimes literally) fairly quickly.
Consider it an item to keep in your spares box.
Ethan Brady
Old 11-30-2010, 12:14 AM
x2
x2
x2
x2
Old 11-30-2010, 03:36 AM
Skeeter74 Skeeter74 is offline
Or, just get rid of the "box" and go HEI. They can be had for well under $100 and only have 1 wire to install.
Originally Posted by Tatsadasayago
"And on the 7th day god created the Full Sized Jeep and he saw that it was good. He gave these mechanical marvels to his chosen ones and they went wheeling in style and comfort!"
80 Wagoneer Limited, 2 bbl 2150, 360, 727TF, NP219, "Moby Dick" Now with Dragonfire HEI, Contour dual fans, CS144,
Old 11-30-2010, 05:28 AM
It could be Vapor Lock. The fuel in the lines going to the carb get too hot and turn into vapor-strving the carb of fuel. I cured this by covering the metal fuel lines with rubber fuel hose.
Old 11-30-2010, 04:15 PM
Thumper168's Avatar
Ok, I repleaced the ICM and the coil and the problem is still their doing the exact same thing it was doing before I replaced them. What is the next thing in line to check? Im getting a little frustrated with this Cold it runs fine but once it heats up it will not run over about 30 mph and bogs down but will not die if you let off the gas. ?? HELP lol
Old 11-30-2010, 05:34 PM
cavicatz24's Avatar
cavicatz24 cavicatz24 is offline
I agree with lawrence - sounds like vapor lock.
I was experiencing the exact same symptoms with Bessie. However, I usually drove her to the point of stalling.
I went the electric fuel pump route with great results. You can also use an inexpensive Mr. Gasket electric pump as a booster pump only - wire it to a toggle and put the pump in-line before the mechanical pump. When she starts bogging or acting like she's starving for fuel the just back off the gas and flip the switch. Only downside to this method is that if your mechanical pump develops a hole in the diaphragm then the electric pump will fill your crankcase with fuel!
You can also try insulating the fuel lines in the engine compartment - Jeg's and Summit both sell silver adhesive insulating tape or ready made sleeves. The hard fuel line from the pump to the carb runs really close to the block and intake and heats up really fast.
Also make sure that your fuel filter is clean and oriented in the proper position - the small return tube should be at the 12:00 position with the outlet to the carb being the center of the clock.
Lastly, make sure your fuel lines are clear. My factory line was badly clogged, thus restricting fuel flow to the carb. Poor flow+low pressure+hot fuel=vapor lock! You can blow it out with compressed air or replace it completely. I replaced mine with 3/8" steel line and never looked back.
"Bessie" 1982 Wagoneer Limited
http://www.ifsja.org/forums/vb/showthread.php?t=120964
Old 11-30-2010, 05:36 PM
If it runs ok when cold and runs poorly when warmed up, I would suspect the difference is the coke is open when warm. This could point to a really big vacuum leak, which makes the engine run very lean. It could also make the engine run like it's starved for gas. If it runs ok below 30, that suggests that the fuel pump can't keep up with the demand for fuel at highway speed, and it's starving.
Another possibility - there are several emissions-related devices (EGR, TCS, among others that are temperature dependent. The factory manual for 1984 Jeep would help with this... I would examine each system - that's it's hooked up right and that it's functioning properly. If the emissions gadgets are't connected right, you can get all sorts of weird symptoms.
I'd also check the plug wires, examine the plugs, and do a compression test. Visually checking the plugs along with the compression test will tell you something about the overall condition of the engine.
Old 11-30-2010, 05:40 PM
Regarding vapor lock, do the simple stuff first. Make sure none of the steel lines are touching metal in the engine compartment. Make sure all the rubber hoses are in good condition. The fuel pump is supposed to circulate fuel from the gas tank, up to the fuel filter and back to the tank. This flow of fuel keeps the fuel cool. Your fuel filter should have 3 nipples - inlet, return, and to the carburetor. Also, if the filter in the tank is plugged, that could slow down the flow of fuel and and promote vapor lock.
The mechanical pumps work fine if they are in good condition and the lines aren't plugged or leaky. Check the simple stuff first!
I worked for a Jeep dealer in southern California in the '70s, and I do not recall vapor lock being real problem with these cars. I'm skeptical ... especially this time of year. Maybe at high altitude, where gas boils more easily, but not on the plains in winter.
Old 11-30-2010, 05:51 PM
Thumper168's Avatar
Ok, I may be a doop!! All the emission stuff was disconected, its still on the motor but just not hooked up any longer. It was all taken loose right before I purchased it, I never thought much about it being dis connected but could this be the issue? Ive read that the cat could cause this problem as well once it heats up? I really appreciate all your help here,
Old 11-30-2010, 05:54 PM
REDONE's Avatar
REDONE REDONE is offline
I agree with the posts about regarding the choke.
Everybody here answers based on their experience, and since everybody has different experiences that makes this forum ROCK!
In my experience everytime I've had the warm-gutless-wonder symtoms like you're describing on EVERY carbureted engine it's happened to, from my FSJs to Dodges and Ramblers, it's been the choke closing for some odd reason. The choke on my PowerWagon is still gagged open with a piece of coat hanger from when I had this same issue last summer, haha!
EDIT>>> You posted while I was typing. A big honkin' vacuum leak from loose emissions parts could definitely cause this too!
79 J-10 - The Money Badger!
304/T18/D20/D44s
What's been did:
Holley 4160/Ede' S.P.2.P.
MSD Streetfire based TFI
Custom-hack gauge cluster
Razor swap
2 knob tape deck!
3" homebuilt lift
Half a hillbilly paint job
Old 11-30-2010, 05:58 PM
Thumper168's Avatar
My choke is pinned open right now, I thought about this and wanted to eliminate the possibility all together. I just want the thing fixed so I can move on to more fun stuff like lifting it, lol
Old 11-30-2010, 06:01 PM
scantar's Avatar
scantar scantar is offline
x3 on the choke. Runs fine when cold (choke's closed) runs like poop on a hot stick when warm (choke's still closed!) That'd be the first thing I would check...make sure the choke's open when it starts pooping out.
[edit] looks like we're all typing with raging fingers If your choke is wired open, then you could be looking at a vacuum leak through all those hoses flopping around loose. Plug them all up and see how it runs [/edit]
Old 11-30-2010, 06:08 PM
Thumper168's Avatar
Everything is plugged up,
Old 11-30-2010, 07:29 PM
You have to troubleshoot it when she does not run, so plan accordingly.
Check for spark, if you have spark then spray Starter Fluid in the carb.
If she starts then, it might be a fuel delivery issue, although is is cool enough that this seems unlikely, although vapor lock can occur.
From your posts it sounds like your ignition system is stock.
The distributor grounds the Ignition Coil Negative side, so with you replacing the Ignition Control Module and the Coil, it is time to take a look at the Distributor.
Sometimes the inside of the distributor gets ionized by the heat and spark from the coil wire. This will cause spark jump and might be something to look into. Take it off and clean with White Vinegar and flush clean after that with ISO Alcohol. While it is wet look for cracks.
The pick-up fcoil for the distributor is your likely culprit, replace the distributor cap and pick-up coil.
With details we can probably walk you through the troubleshooting problem.
Logical, step by step troubleshooting will get er done... unless your wallet can stand the hit, if it can....
Mallory Unilite Optical Distributor
http://go.mrgasket.com/ProductImages/500/4760001.jpg
http://www.summitracing.com/parts/MAA-4760001/
Mallory Promaster E-Series Ignition Coil
http://www.malloryperformance.com/ProductDetails.aspx?modelNumber=30451&productID=20 66&majID=545&minID=5457&selection=4&minselection=6
http://www.summitracing.com/parts/MAA-30451/Application/?prefilter=0
Taylor 8.2mm Spark Plug Wire Set
http://www.summitracing.com/parts/TAY-84603/Application/?query=Make%7cJEEP%7cModel%7cWAGONEER%7cEngine+Siz e%7c5.9L%2f360
Old 11-30-2010, 09:10 PM
Thumper168's Avatar
It has a new pick up coil and cap, The items I have replaced in the last week,
1 Pick up coil
2 Ign. Coil
3 Ign. Control Module
4 Dist. Cap
and it still runs like Pooo
Strange Coil/Timing Issue jdaniel83 General FSJ Tech 3 09-03-2009 08:10 PM
Was running good, then suddenly not so much... RED-85-Z51 General FSJ Tech 20 04-12-2009 06:03 AM
Stopped running seriouswood General FSJ Tech 3 04-02-2009 05:34 PM
Running 'pane on 258 Richomino General FSJ Tech 5 08-30-2006 03:00 PM
OT: chavy 350 running like poop 83 BEAST General FSJ Tech 2 08-01-2006 04:59 PM
