Old 05-25-2004, 12:09 PM
WalterX WalterX is offline
I hoping someone with an early FSJ has a fix for the heater contols. I have searched everywhere and have come up with nothing. Here is a photo of the piece I'm talking about. I've cleaned everything. The two metal disks leak enough so that it won't control anything anymore. All the hoses are new/good. There is good tension on the spring. Is there supposed to be a gasket? Are they supposed to be machined so close as to not need a gasket. What am I missing?
1943 Willys MB
1970 Jeepster Dauntless 225
1971 Wagoneer Dauntless 350
Old 05-25-2004, 01:48 PM
JeepBountyHunter's Avatar
GrimJeeperReaper
I'm not sure about a gasket, but try a little solder...or JB Weld. (Try JB Weld first). Or, that almost looks like a 70-early 80's type pushbutton deal mounted sideways, instead of level like on later rigs, might be interchangeable??? (like maybe you can take the pushbutton assembly off a later rig and mount it sideways in yours...I'm not entirely sure of this, as I've never seen one personally save for pic's like yours.
1992 Cherokee XJ Laredo
Old 05-25-2004, 02:05 PM
carrotman carrotman is offline
I agree with JeepBountyHunter in that it looks like a vertical mid-70's. Where your finger is, is that the vacuum switcher to the air doors? If so, might be the same as mid 70's. And you can get one from a junk yard.
76 Chief, T18, 3.54, HEI, Carter AFB.
Old 05-25-2004, 02:20 PM
Crazy_Jeepman's Avatar
Sloppy Shifter
Easy stuff, CLEAN and LUBE. I just took this one apart to show you what you have. Pretty much the same steps as shown below
Old 05-25-2004, 02:25 PM
Sloppy Shifter
And yes it is the same switch used in the 73 to 85 Jeeps [img]smile.gif[/img]
Old 05-25-2004, 03:29 PM
Crazy jeepman: I'm impressed.
Old 05-25-2004, 04:07 PM
Thanks for the replies.
Yes carrotman, that does go to the air doors. Holy cow Crazy_Jeepman!! Thanks! I didn't try vaseline. I was thinking of using marine grease. It won't run when it gets hot it there. I did use some 1000 grit sandpaper and a granite block to make sure I was sanding on a flat as possible surface but I still can hear the woosh of air while just sitting at idle and it's enough so they won't function. I don't think I can get those two surfaces any smoother without som precision milling. I'll have to try though. Yes, I did put a vacuum pump on the canister, it holds perfectly. Good line, good canister. I'll have to try the local boneyard. There's a couple late 70's out there that may have a "used less than mine" piece on it.
I was looking into a way of getting rid of the vacuum all together, if I can't get the original working, by adding micro-switches to the back of the unit and changing the canisters to electric ones or some small solenoid. I don't think these were meant to last this long otherwise they would have made a better design. It is quite simple and probably was very cheap.
[ May 25, 2004, 11:06 PM: Message edited by: WalterX ]
1943 Willys MB
