Old 02-13-2001, 03:56 PM
swclemons swclemons is offline
I hate my 2150!! I have had the thing rebuilt 3 times every time back to the same problem. When I dump on the gas it wants to stall, If I ease on the gas no problems.
I think its time for a new Carb....
Steve
87GW Stock
Old 02-13-2001, 04:04 PM
porkchop's Avatar
porkchop porkchop is offline
Master of B.S.
Did you check out the post on the carb plate? It might cure your problem.
'67/'79 Wagoneer mix
“Old Timer”
Check it out!
Mods, Mods, and more Mods! The end is no where in site, but I am sure I am closer to the fork in the road.
Old 02-13-2001, 04:19 PM
jeepbob jeepbob is offline
Jeep Idiot
That or a little more timing. You did make sure the accel pump on the carb was working and adj properly, right?
65 wag. 360/edelbrock rb4/t400/20 t-case/4:10 d27/d44 tracloc/onboard air/onboard 110v power(no inverter)/1999 Lincoln t.c.leather buckets/taurus ctr console/winch/33x12.50/tunes/water proof door pads
soon to have new motor/d44frt/d60r(4:10)welded diff/custom bumpers
see ya in da mud
Old 02-13-2001, 04:52 PM
The Acc Pump was the problem the last time, and I am suspecting it again, however I am going to check the Carb Plate. If I decide to get a new Carb which one is best???
Steve
Old 02-13-2001, 04:55 PM
Jeep Idiot
There are many different opinions here, check a little further back in this forum, and you will find a couple of good debates.
(I like my Holly 4160)
see ya in da mud
