Old 12-13-2000, 02:09 PM
swclemons swclemons is offline
Whats the best for sticking locks??? Its getting so hard I think I will break the key off trying to unlock it. I've tried WD40 with no help??
Steve
87GW
360/Stock
Old 12-13-2000, 02:19 PM
trickc's Avatar
trickc trickc is offline
I used a tube of graphite,i think i got it at a locksmiths or even auto parts store.Be sure and spray the latch mechanism also,I seem to recall that helping too.
74 cherokee nt,4"lift,
33's,lockers,winch,custom bumpers,what else is there?
Old 12-13-2000, 02:24 PM
GRAT GRAT is offline
Check the threads on locks in the tech advice section on the home page.
79 Chero WT/ TH400 /QT /360 /3" Dynomax / K&N
78 Chero WT 360 TH400
Old 12-14-2000, 02:11 AM
bigbry bigbry is offline
Exclamation
I had phantom locks yesterday, at 10 degrees my locks decided to dance for 30 minutes, they locked and unlocked on there own...I finally locked them and fice minutes later they all popped up again and did the dance..up,down,up,up,down,up........maybe the big boy is haunted??????
BigBry
"Full Sized Jeeps for Full Sized Guys"
1989 Grand Wagoneer "Old No. 7"
stock, for now
1985 Dodge Ram 150 Custom "The Big Red Machine"
restoring
Always working, never done!!
Old 12-14-2000, 02:42 AM
tuckers89GW tuckers89GW is offline
My advise would be to lube all the pivot points in the linkages and latches. I have found that gravel dust is bad for them. Use a good quality lube or grease.
Mike
<UL TYPE=SQUARE>
<LI>'89 GW
completely stock
<LI>'99 Windstar
under WARRANTY
<LI>see JEEP[/list]
Old 12-14-2000, 02:55 AM
trickc's Avatar
BigBry I'd have to say you got a loose connection( in your wag that is!)
