Old 02-26-2001, 02:55 PM
swclemons swclemons is offline
Post
Still tracking down my stalling problems, however, after reading the post about the return fuel line, I had a questions. If the return line were blocked could it cause the stalling on hard acceleration problem??? Possibly my new pump could be overdoing it???
Old 02-26-2001, 04:10 PM
jeepbob jeepbob is offline
Jeep Idiot
Post
Really don't think so. if it is stalling when you stomp the gas, check the accelerator pump to see if it is working. Also check engine timing.
65 wag. 360/edelbrock rb4/t400/20 t-case/4:10 d27/d44 tracloc/onboard air/onboard 110v power(no inverter)/1999 Lincoln t.c.leather buckets/taurus ctr console/winch/33x12.50/tunes/water proof door pads
soon to have new motor/d44frt/d60r(4:10)welded diff/custom bumpers
see ya in da mud
Old 02-26-2001, 04:17 PM
401chief 401chief is offline
Post
kinda sounds like either a vacuunm leak or not enough fuel problem. what kinda carb do ya have?
Old 02-26-2001, 05:10 PM
Post
I have a stock 2100/2150 2bll. I have had it rebuilt twice in the past year. Timing is right on, the only thing I have changed in the past months was the fuel pump. I didnt have the stalling problem before I changed the pump, but the Jeep sat for about 2 weeks before I fixed the fuel pump.
Old 02-27-2001, 08:25 AM
Cool
have you checked your fuel filter?
a while ago i had a problem similar to this, it turned out to be A LOT of rust and dirt that had built up in my gas tank plugging up my pickup and fuel line
Old 02-27-2001, 08:59 AM
Post
I changed that when I changed the fuel pump.
What about the screen in the carb, could that be ocluded??
