Old 03-24-2007, 05:52 PM
icuhatn99 icuhatn99 is offline
need reverse offset wheels/deep dish to fix narrow axle appearance
Hey ..I am just about finished with a pretty major swap(never done anything like this ...and probably never again!!)...took frame/running gear of wrecked 79 cherokee s narrow track and put it under a 79 cherokee chief wide track.....now the thing looks kinda funny having narrow axles on a wide track body....I would like to get some kinda deep dish / reverse offset wheels that stick out farther to compensate for the narrow axles....any suggestions of a style/offset that would work best for me in a 15x10 wheel.....thanks
Old 03-25-2007, 04:06 AM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
Why not swap the WT axles under it? You'd be much better off that way. Bart makes a 2.5" backspaced rim in the 16.5" Super Trucker, they may have one in that backspacing for the 15" rim as well.
Old 03-26-2007, 07:47 AM
I did'nt have the wt axles...
Old 03-26-2007, 09:50 AM
scumby's Avatar
scumby scumby is offline
i'll trade you a WT for an NT? i'm moving to eastern washington next month.
should be a bolt in affair. mine has 3.31's. i think it needs ball joints. if your willing we can work something out.
al
