Old 01-12-2007, 11:31 PM
rreed's Avatar
rreed rreed is offline
Question Have searched (a lot), latest TFI parts list and HEI/TFI wiring diagrams?
I've spent a few hours this evening searching all over (here and Internet) for the latest parts list for TFI for AMC V8s. Seems there are a few slight differences in what people are getting, seems earlier postings seem to list '79, '84, 86 Ford Fx50 parts, while somewhat more recent postings seem to suggest '92 F350 w/ 460, EEC (or ECC?). I also noticed some folks had to make a couple trips back to the parts place because some parts didn't exactly work well together or just got the wrong thing in the first place.
What is the latest and greatest parts list to ask for at the parts counter?
I've also kept track of (though apparently never downloaded) HEI/TFI wiring diagrams, mostly by JYG and John Strenk (from JU's CJ Forum). The last one I saw seemed to indicate JYG has since added a diode somewhere in the mix. I can't find it now.
I'd like to see please the latest and greatest wiring diagram and have some questions about the capacitor and diode. Maybe this might be good for the recent request for archive material?
47 Willys
75 CJ-5
81 Scrambler
96 ZJ
Old 01-13-2007, 01:51 AM
DanHS's Avatar
DanHS DanHS is offline
Well I used the MSD Cap-A-Dapt cap and rotor kit, $32 on Summit, spark plug wires for a 5.0/5.8L Windsor Ford (like in an 80's Mustang and most 80s V8 Fords, I used $41 Ford Racing wires), and a new e-core coil that was $25 from the local parts store. Mounted the coil on the left fender behind the washer fluid box, soldered some extension wires that simply plugged into the old coil wires, and called it done. Runs much better now. Coil doesn't get 12volts, but I'm afraid of the module burning out from trying to ground the 12 volts. I plan to switch to an aftermarket module and use the full 12 volts, not sure what yet, either an hei style module or 80's Ford module that is less expensive, or an MSD style box like an MSD 6-AL.
My FSJ pics
FSJ Grille Identification
