Old 10-25-2021, 02:44 PM
drcom's Avatar
drcom drcom is offline
1969 OVER DRIVE ????
I was looking at some older pics of a 1969 Wagoneer that was found in a barn in California. As I blew up the photo to look at some interior details, I see a pull handle on the dash that says Overdrive !!!!!!!!!!!! Wow, has anyone heard of this ? I don't think it was factory so it had to be dealer installed. What could they possibly have put in ? I am very intrigued. Look just below the turn signal.
1970 Wagoneer Custom (9/1969)
Original Arizona Jeep
Buick 350/TH400/Dana20
Early model with razor grill
Spring Green exterior (original)
Custom series interior
Old 10-25-2021, 03:11 PM
Heep-J4000's Avatar
I'm not old enough to speak from personal experience , but I know that back in the day there were option to bolt on a external overdrive to the transmission.
Warn and mile marker were two of them that did make them.
There were a lot of other brand names that are long gone that made very cool on and off road parts!
Have a look in some 1970 fourwheeler magazines and start drooling over al the ads about cool parts and other interesting articles.
One of the cool options from back in the days I would like to have on my 73' J4000 would be a sidewinder winch from Hickey.
Trucks/car's from the past:
Old 10-25-2021, 05:28 PM
goldhammer's Avatar
Would venture it would be a Warn.
Art
ASE Master Collision Tech
Old 10-26-2021, 10:46 AM
The Warn/Saturn overdrive is a planetary overdrive transmission that only works with a Dana 18 transfer case. Not applicable to our FSJs. There were also Rancho overdrives which adapted the Borg-Warner electric overdrive used on many automobiles to the Dana 20. Look here - https://classicbroncos.com/ebbarn/overdrive.html
These were available for Jeeps as well as Broncos. Note they fit on the rear output of the Dana 20, and thus only work in 2-wheel rear-wheel drive.
Old 10-26-2021, 07:44 PM
backroadin''s Avatar
A 3-on-the-tree I see. Something a little funky going on with that 4wd lever..... that wasn't how they were stock, were they?
Old 10-27-2021, 05:33 AM
drcom's Avatar
Yes, the shifter is like that on the Kaiser Era Jeep Wagoneers.
Old 10-27-2021, 10:29 PM
SJTD SJTD is offline
Looked at the link Tim provided. That's the unit that was in a Wag I scrapped out. Held on to it for years to maybe use, then couldn't give it away. No internet back then. At least not like now.
I thought it was a factory option since I had a manual, that I thought was factory, that covered it. Loaned that book out many years ago and never got it back yet so I can't be sure.
Seems to me you had to lift off the gas to let these things shift, contrary to what that article stated. Once engaged there was no compression braking.
Sic friatur crustulum
Old 10-28-2021, 11:02 AM
Originally Posted by SJTD
I thought it was a factory option since I had a manual, that I thought was factory, that covered it. ...
Both the T-85 and T-89 3-speeds were used by Jeep in these models, and in passenger cars both could come with the B-W overdrive. Possible the 2WD Wagoneer could have one from the factory, which would explain its being in whatever book you had.
Driveshaft: Drive Flange vs. Drive Yoke threepiece General FSJ Tech 0 03-24-2015 08:06 PM
HEI Drive Gear Theory? ThisGuyUKnow General FSJ Tech 3 10-30-2013 08:44 AM
Anyone put a CRT HEI distributor on their FSJ? rjgilliam General FSJ Tech 28 04-20-2009 10:50 AM
two different size rear drive shafts? WTH roadgrime General FSJ Tech 12 09-20-2004 02:56 PM
Stuck in Emergency Drive 1BAD401 General FSJ Tech 12 05-20-2002 09:34 AM
