Old 07-06-2013, 05:09 PM
Rich88's Avatar
Rich88 Rich88 is offline
TFI coil buzz?
So I'm getting ready to install a relay to feed my recently installed TFI coil with system voltage instead of the 8.8V it currently gets thru the stock resistive wire. First thing I did was (while engine idling) was to test-jumper from battery (+) terminal right to the coil (+) just for the heck of it.
I instantly got an unexpected loud buzzing from the coil and thought maybe something was about to fry. After carefully tapping the coil (+) with the jumper a few times I realized it was really "transformer buzz" and being caused by the fact that the coil body is not really tight in the steel shell surrounding it, and its simply electromagnetic energy causing the coil to beat against it, and the act of providing it with higher voltage just made it work harder...providing the increased sparkage it should.
But it really IS a noticeable nuisance buzz, and worse than one tolerates with an e-pump. After staring at it for a while it occurred to me that maybe I could put the coil on the bench and drizzle epoxy into the crack-spaces between the coil and shell to get rid of the play.
Anyway, is this buzz typical? Did I get a lousy coil? Thoughts?
Old 07-06-2013, 06:38 PM
serehill serehill is offline
Gone,Never Forgotten.
Interesting
Never heard of that but the theory sounds logical. I would think the coil has some flaw in the casing.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 07-06-2013, 11:34 PM
FSJ Guy FSJ Guy is offline
New coil? Take it back. Used coil? Get another one.
Ethan Brady
www.bigscaryjeep.com
Old 07-07-2013, 05:47 AM
Rich88's Avatar
What the heck, I'll try the epoxy thing.
Old 07-07-2013, 10:19 AM
yeah
I went that way the first time. My coil is epoxy. No oil coils for me. The blaster 3 is what I'm running.
So I'm just curious. You connected the 12 volt wire while the 8.8 volts was still connected to it?
I guess anything is possible I would assume the vibration would be from a loosely wound coil getting epoxy to saturate the entire circumference means there's no oil where there should be. You might want to also verify the input voltage of the coil I have no idea if it is correct. It should have been a 13.8 v coil.
I agree if this is from the mounting being loose then tightening the bracket should have fixed it. I would be concerned the coil windings are touching the outside casing. If that is the case it has a manufacturing flaw & when the insulation wears off the coil then Bye Bye Coil.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 07-07-2013, 02:26 PM
Rich88's Avatar
I used the one for the 80-something Ford F350 460.
Yeah, it was idling with stock 8.8V feeding it. I just tapped the coil (+) with battery to kick it up momentarily. Also, I jammed some small wood shims in the space between the coil and the frame. No change. Apparently the buzzing IS internal. So I'll drive it down to Advanced Auto to have them listen to justify getting another.
I just completed the re-config for system voltage. See separate post.
Ford TFI vs. MSD TFI coil schnerdad General FSJ Tech 6 01-18-2007 01:08 AM
TFI Conversion Slightly Simplified Rande General FSJ Tech 4 10-31-2003 01:33 AM
HELP. TFI COIL hook up. RudyC General FSJ Tech 5 12-03-2000 12:37 PM
