Old 07-01-2013, 05:25 PM
Blue88's Avatar
Blue88 Blue88 is offline
Flat towing with a 229 TFC
Hope to buy another G.W. this holiday weekend as a parts car. I wanna use the drivetrain parts to rebuild and swap into the wife's rig. That way theres less down time . The front shaft is out for whatever reason. It won't start, so is it safest to pull the rear shaft and get it on a dolly? I've read about trashing the v.c. and would like to avoid damaging parts.
Thanks,
88 Grand Wagoneer, 360,727, 229, 3.31 dana 44s. TFI conversion. 2 inch rough country spring/block lift. Pátina and faded wood grain.
Old 07-01-2013, 05:56 PM
Pull the shaft = safe bet. Just don't forget when you disconnect so it doesn't roll away!
Old 07-02-2013, 01:01 AM
FSJ Guy FSJ Guy is offline
I would remove the rear driveshaft as well. There are ways you could do it without doing that, but why chance it? 4 bolts at the rear axle and the driveshaft is disconnected. Wire it up with baling wire and tow it on home.
Ethan Brady
www.bigscaryjeep.com
Old 07-02-2013, 04:06 AM
Blue88's Avatar
Thanks for the advice guys. I'm not going far with it, just don't want to break stuff I need for later.
Horrible Towing Stability jbentley General FSJ Tech 14 10-04-2011 07:32 AM
FLAT TOWING AN 83 J10 FSJ-Earl General FSJ Tech 18 11-20-2007 06:02 AM
FLAT TOWING WITH A FSJ FSJ-Earl General FSJ Discussion 2 07-16-2007 09:06 AM
Towing setup Campcar_david General FSJ Tech 4 08-29-2004 05:22 PM
flat towing '82 sj clabner General FSJ Tech 3 05-11-2002 01:29 AM
