Old 02-19-2013, 09:35 PM
Austin 4x4's Avatar
Austin 4x4 Austin 4x4 is offline
narrow track street truck?
so mabey i have been thinking too much, but what if someone were to make a lowwered narrow track street truck? start with a 80's shortbed truck swap out the axles for narrow track ones, lower it an inch or two. change out the fenders. hard part is going to be the 1/4 pannels, easy way would be to find a two door narrow track cherokee and use its 1/4 pannels. but those are geting hard to find in good condition. you could also use a wagoneer but it would be more involved. so thoughts, is it a good idea?
'73 J4000 4 door longbed http://www.ifsja.org/forums/vb/showthread.php?t=120147
'85 Wagoneer
YES i WILL be in ouray in 2013!
Old 02-21-2013, 07:51 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
Guess my question would be why you'd want it narrower? Even lowered, wider seems like it would give way better performance/handling. I supposed if maybe you like the narrower look better??
aa
Old 02-21-2013, 08:54 PM
Austin 4x4's Avatar
i would only want to use narrow track axles so i could fit the tires under narrow track flares on a truck bed.
'85 Wagoneer
Old 02-21-2013, 09:34 PM
Cecil14's Avatar
So I'm assuming it is the N/T look you're after then? You can do just about whatever you want with wheels/tires/backspacing to get the rubber you want under there.
aa
Old 02-21-2013, 10:18 PM
The NT rear axle will not fit unless you inboard the springs and even then tires will probably rub the back side of the fender wells. You have fab skills so this would not be impossible.
Old 02-23-2013, 12:24 AM
j10jim's Avatar
j10jim j10jim is offline
street truck with narrow front tires/rims and big fatties out back. Then you can use the narrow track fenders in front and use the flared bed to cover the big fatties in back!
1980 J-10<br />Rusty\'s 4 inch lift<br />2 inch body lift,<br />35 in Xterrains on J20 axles<br />4:30 gears<br />Detroits<br />In-Cab cage thru the dash
Old 02-23-2013, 09:43 AM
TPICherokee's Avatar
x2, part of the reason the J-truck rear axle is wider than a Cherokee Chief is because the frame is wider, which makes the spring perches wider which means a N/T axle won't fit without moving the springs...
Old 02-23-2013, 08:26 PM
Austin 4x4's Avatar
it would probably be easier to back have the frame. and if you are going to do that might as well build a four link with some airbags. sometimes i think i think to much about stuff.
'85 Wagoneer
Wheres the coolest place? capdaddy222 General FSJ Discussion 28 07-12-2011 09:06 AM
Narrow track 5 lug vs 6 lug xtremos General FSJ Tech 2 04-10-2009 09:09 AM
Narrow track D44 experts needed.... TooRisky Off-Road FSJ Tech 6 03-27-2009 08:47 PM
Dana 44 Narrow Track axels limits and user experience. nitrooxide General FSJ Tech 5 03-19-2009 06:46 AM
Narrow track 3/4 ton front axle AKAMC General FSJ Tech 12 02-15-2009 09:23 AM
