Old 11-14-2011, 10:26 AM
chrisnsarah's Avatar
'67 Gladiator-sloppy column shift linkage
It's so bad that sometimes you can't get it in park and you may have to go down into 2 or 1 just to get it into drive and go to N to get it into reverse. I can't even get into manual 1st gear. The transmission still clicks in the detents if I crawl under and do it manually.
I had my son fiddle with the shifter while I watched the linkage at the base of the column and there's a fair amount of slop before the underhood linkage even moves. I wondered what is involved to tighten or repair this. I don't have any problem removing the column and disassembling it. It's not my DD, so I have a while to mess with it. I can't really tell what could wear out by looking at the diagram in the TSM.
'64 J200 thriftside
'67 J2000 townside custom cab
'68 Jeepster Commando
'69 Super Wagoneer
'75 J10
'79 Cherokee S WT
'75 Cherokee
'61 Aristocrat Lil Loafer
best shift linkage between a 360 V8 and a 727 torqueflite in a 78 J-20 soxcloud General FSJ Tech 3 12-20-2009 07:35 AM
Shift Linkage Question BigOlWoody General FSJ Tech 2 06-07-2009 12:01 AM
Help! Column shift ignition switch budojeepr General FSJ Tech 7 03-08-2009 07:54 PM
TH400 shift linkage...adjustable? PlasticBoob General FSJ Tech 10 05-30-2008 10:38 PM
AT shift linkage adjustment? BigRedChief General FSJ Tech 2 03-08-2007 10:20 AM
