Old 10-05-2021, 04:07 PM
got the willys got the willys is offline
Carb for a 360
Need to put a new carb on my wife's 88GW and wondering what the recommendation is these days. GW is a driver with 140k on the clock. I'm trying to get it ready for colder weather and don't think I want to have the Motorcraft that's on it rebuilt; unless you guys think otherwise. I usually go with Edelbrock.
Thanks for your opinion.
Thanks,
Victor
88 GW
79 AMX
Old 10-05-2021, 05:40 PM
bluehwy's Avatar
bluehwy bluehwy is offline
I had an Edelbrock 4 barrel on my 79. Gave it to my niece for her Apollo. She ended up buying a new one because mine wasn't a match. I can check and see if it's still available. It was running when I took it off but I'd put a rebuild kit to it.
Previous: 1989 or 90? Maybe a 91... Grand Wagoneer
Current: 1979 Wagoneer, 1989 Grand
"Well I've been down so God damn long! and it looks like up to me..." Furry Lewis (but Doors version)
Old 10-05-2021, 07:48 PM
dirt cheap and stupid simple to rebuild the stocker.
for a stock daily driver it'll get the job done easily.
http://www.ifsja.org/forums/vb/showthread.php?t=101921
My kiddo could rebuild one.
Old 10-06-2021, 04:13 AM
Brynjminjones's Avatar
A second vote here for rebuilding the stocker!
I'd never touched a carb before rebuilding ours, and honestly found it incredibly easy. Very simple to tune too, and mine has been dead reliable since.
1991 Grand Wagoneer - Hunter Green. All stock. Rebuilt 360 with Melling MTA-1 cam.
1998 Cherokee (XJ) 4.0
1997 Grand Cherokee (ZJ) 4.0
1974 Ford F100 390
Old 10-06-2021, 07:46 AM
inkedmonkey inkedmonkey is offline
Holey 500cfm 2 barrel on mine. Love it
Old 10-06-2021, 11:50 AM
+1
Old 10-06-2021, 02:02 PM
Thanks for the suggestions. I'm cheap and stupid for sure. I've rebuilt so many carbs I just don't want to do it anymore. I want wondering if one of the newer Ebrock AVS models would be better, but if the old Motorcraft will work just fine, I'll have it rebuilt by a guy I knows who does them.
Thanks again.
Thanks,
Victor
88 GW
79 AMX
Old 10-09-2021, 08:10 AM
By all means if you want throw a 4bbl intake and carb on there go for it.
However, I wouldn't go through the expense or hassle on a stock engine.
You would be approaching Holley EFI Sniper 2300 territory if using a new intake/carb.
Old 10-14-2021, 01:30 PM
Bc409 Bc409 is offline
Carb
I am using the Summit brand 4bbl 600 cfm vac secondary electric choke. Even after rebuilding the 4350 it was miserable. The new carb is great. My 1978 wagoneer starts great and runs even better now.
Old 10-16-2021, 10:36 AM
My experience - the Holley 2300 is a great carburetor on the street, but lousy on the trail. BTDT. The original Motorcraft works well on the trail (well known as an excellent off-road carb), and gets about as good a fuel economy as can be expected from that engine. The Holley has better performance, is more tunable, and gets significantly worse mileage.
Throttle body fuel injection would be an excellent upgrade. Economy, performance, drivability. The Holley Sniper is easy to install and well-liked.
Old 10-16-2021, 06:02 PM
backroadin''s Avatar
backroadin' backroadin' is offline
Well, I'm gonna be in the minority here, but...
I think a quadrajet is a good option. Small primaries for fuel economy and streetability, and vacuum secondaries for only as much extra oomph as your engine can use. Oh, and with center fuel bowl, they're great off-camber. I have one on my 6 and it works great. Actually had to richen up the primary side a bit.
Otherwise, I vote for edelbrock with vacuum secondaries. Easy to tune and simple.
"When this baby reaches 88 miles per hour, you're gonna to see some serious sht!"
Old 10-17-2021, 04:08 PM
I replaced by Edelbrock with a Street Demon and it has worked well on the road [I havent been off road with it]. I did change the metering rods in it to minimize a Bog--they are like the Edelbrock and dont have power valves.
Old 10-21-2021, 03:30 PM
57farrell's Avatar
57farrell 57farrell is offline
Have Holley 4412-8 1818 2 barrel electric choke 500cfm I took off my Grand Wagoneer. Not stock carb.
Will take 100.00 for it.
Email me at 57farrell@comcast.net
will ANY Motorcraft 2150 carb fit 360? Jeep'rs Creep'rs General FSJ Tech 12 11-17-2011 08:02 PM
Carb replacement - Jeep 360 77' npbsurfr General FSJ Tech 9 03-23-2011 03:35 PM
83 wagoneer 360 2bbl carb not so good tazzerzz General FSJ Tech 12 02-01-2007 07:17 PM
87 360 backfireing through carb. slick64 General FSJ Tech 13 12-10-2006 06:06 PM
Carb CFM rating for 360? Richomino General FSJ Tech 36 11-02-2006 10:21 AM
