Old 03-23-2021, 12:48 PM
mwood65's Avatar
mwood65 mwood65 is offline
Shifter seal?
I think I have a missing part but don't know what it is.
The shifter for my Dana 20 has the grommet thingie in the carpet where shifter comes through the carpet but below that it is just the hole in the floor.
When cruising down the road cold air just blows in through the hole pretty bad.
Isn't there supposed to be some kind of seal or something there to keep the air out? Right now I have rags stuffed around it to keep the cold out......Looks like crap but works for now
Old 03-23-2021, 01:14 PM
Heep-J4000's Avatar
It's missing a shifter booth and rubber plate with opening for the stick.
The booth is a square kind of booth and put into the floor opening upside down.
The seal on top is a flat piece , you could cut one out of a thin piece of flexible rubber plate.
Trucks/car's from the past:
Old 03-23-2021, 01:31 PM
Heep-J4000's Avatar
https://www.justjeepsters.com/produc...ifter-boot-new
mwood65's Avatar
Thanks for the quick reply!
I have the rubber piece on the floor as shown in pic but under that is just a hole in the sheet metal, you can see the ground through the rubber slot.
I figured there HAS to be something under the floor to seal the hole but can't find anything on sites for sale or anywhere else. I can't even find a picture so I know what I am dealing with.
This is what I have now ...
Old 03-23-2021, 01:33 PM
mwood65's Avatar
WOW, thanks for the link. I am ordering one now.
Never even seen that site before.
Thanks a TON bud!!
Old 03-23-2021, 01:34 PM
Heep-J4000's Avatar
Something like this upside down into the body opening.
https://www.omix-ada.com/sr4-shifter...cj-models.html
Old 03-23-2021, 01:38 PM
Heep-J4000's Avatar
The upper piece you have is still looking good so keep that and put a shifter booth upside down in between the body and the upper piece you have!
Lining up the holes or finding the existing holes could be difficult with everything together at once!
Old 03-23-2021, 04:29 PM
mwood65's Avatar
That pic isn't my jeep but it is the same piece. Just didnt have a camera handy to take a pic of mine...lol
Wish my carpet looked that good.
Old 03-23-2021, 07:51 PM
goldhammer's Avatar
Should have the accordion type boot over the top of everything, like the CJ one shown in the omix link
Art
ASE Master Collision Tech
Old 03-25-2021, 11:41 AM
Heep-J4000's Avatar
My J-4000 had a booth upside down into the body opening because the transfer stick doesn't stick out that long.
It was a booth without the harmonic model but looked pretty original.
Rear Main Seal.....what I learned Chief Gunner General FSJ Tech 5 08-30-2010 08:14 AM
True/False? Front main seal = crankshaft seal CustomWag General FSJ Tech 1 06-26-2007 04:27 PM
Quick, what's the dimensions of the o-ring on the trans shifter? DanHS General FSJ Tech 3 11-08-2006 03:44 PM
leak at the shifter seal CaliGWagon General FSJ Tech 9 04-19-2003 03:31 AM
Shifter shaft seal ??? L. Vargas General FSJ Tech 3 12-21-2002 03:38 PM
