Old 04-23-2012, 07:01 PM
stonehengeheels's Avatar
stonehengeheels stonehengeheels is offline
"87 vs '90 GW Engine Wiring Harnesses
Other than the starter realy on the fender are these harnesses the same? Thinking of swapping the one from my '87 to my '90 due to PO damage/splicing. Thanks.
Steve
'87 GW (Totaled)
'90 GW (Under renovation)
'00 GC Laredo (Totaled)
'02 GC Laredo (Sold)
'67 Dodge Coronet Convertible 440/727/3.55
Old 04-24-2012, 08:50 AM
AM Woody AM Woody is offline
I had both years, the plugs for the ignition module were different. And isn't the AC compressor different? Don't know if that affects the harness.
- Andy M.
89 Grand Wagoneer: White/Cordovan. Factory tow package. Gradually undoing PO's mods - it seemed like a nice build at the time.
Status: Operational
Old 04-24-2012, 09:34 AM
There are several small differences, it won't be plug it in and go, you'll need to make changes to the '90 harness.
Old 04-24-2012, 09:45 AM
AnalogKidKC's Avatar
AnalogKidKC AnalogKidKC is offline
I had an 87 "parts" GW and drive a 89. My ignition module went bad. I pulled the one off the 87 and went to put it on the 89 No go. 87 has round connections and 89 has the "new" square watertight connections.
Aren't "improvements" fun.
89 Grand Wagoneer. 3" lift Stock for now.
Old 04-24-2012, 02:50 PM
Thanks guys.
Steve
'87 GW (Totaled)
Check out my wiring diagram gte901m General FSJ Tech 32 11-08-2009 09:09 PM
Engine noise, 4.0 swap???? Mex in the city General FSJ Tech 5 11-24-2008 04:00 PM
Wiring Conundrum (Dash and or Engine) spyderkeeper General FSJ Tech 13 10-19-2008 08:57 PM
HELP!!! Engine wiring woes stork08 General FSJ Tech 0 09-16-2007 10:21 AM
trying to remove engine wiring harness, but having trouble... Sycho15 General FSJ Tech 2 03-25-2003 01:37 PM
