Old 09-26-2015, 01:21 PM
see2xu's Avatar
see2xu see2xu is offline
Disaster Strikes
3 years and a lot of Benjamins, and I finally get it back on the road. Out for a shakedown, after a series of dyno runs, and some short trips at lower speeds, when the oil pressure goes to zero, and I'm on the side of I-40.
Made the mistake of buying an engine from a backyard builder. Never again. Sending my original long block off to have it done, and chalking this up to lessons learned.
Old 09-26-2015, 01:41 PM
BigOberg's Avatar
BigOberg BigOberg is offline
oh i wish i had a cool handle.......
Sorry to hear that Hopefully you'll be back on the read sooner rather than later
Follow my build http://www.ifsja.org/forums/vb/showthread.php?t=174682
1989 Grand Wagoneer: 360-727-229, 4" BJ's Lift w/32's, Howell Fuel Injection, TFI Conversion
2012 Jeep JKU Sahara: 3" Lift & 35's
Old 09-26-2015, 02:52 PM
8man's Avatar
8man 8man is offline
Tough break. Hope the next one is quicker and you are back on the road soon.
Old 09-26-2015, 03:57 PM
i'd dig into the block a bit. especially the timing cover. these have retarded oil system on them,and you may have a pump relief valve in backwards or something. or a galley plug fell out in the timing cover or under the intake.
real gauge or the electric oil p gauge?
Old 09-26-2015, 05:02 PM
Tanker Tanker is offline
Beats me got mine running,then rear ended by old man. Now totaled frame bent rear end crushed.
Owner of Jakes FSJ Junkyard 91 Jeep Cherokee /2006 3500 Dodge AKA Babe the big blue puller
Hire the handicapped, they are fun watch!
Old 09-27-2015, 06:40 AM
see2xu's Avatar
Electric, but it was reading on the low side (not critical) after warm-ups, not enough to provoke panic. And the soundtrack definitely jived with the reading on the gauge.
Old 09-27-2015, 08:18 AM
pull the intake first. you may have a galley plug laying in the valley. there is also to behind the cam timing sprocket. there is 2 on the rear of the block but those would pump oil onto the ground.
Old 09-27-2015, 09:13 AM
Was it making noise/clattering?
QT disaster averted hennikerjd General FSJ Tech 6 01-31-2011 12:13 AM
plastic fuel tank strikes again originalrecipekenny General FSJ Tech 0 01-09-2011 07:51 PM
2 Quarts near disaster 1jeep4me General FSJ Discussion 1 11-12-2010 05:13 PM
Murphy's law Poster Child Strikes again!! or Sean's luck bigun General FSJ Discussion 11 08-31-2009 12:03 PM
