I was reading up on valve cover tags and according to the two place I found that have code explanations, my code is incorrect. My code is 203p08. This code signifies a 1969 or 1978 AMC 360 with a 4bbl intake (which were only supposed to be made from 70-77), made on Mach 8th. Just thought this was an interesting discrepency and I was wondering if anyone else has had an issue such as this?
Valve cover tag code?
Originally posted by highspdlife0224I was reading up on valve cover tags and according to the two place I found that have code explanations, my code is incorrect. My code is 203p08. This code signifies a 1969 or 1978 AMC 360 with a 4bbl intake (which were only supposed to be made from 70-77), made on Mach 8th. Just thought this was an interesting discrepency and I was wondering if anyone else has had an issue such as this?Tim Reese
Originally posted by tgreeseWhere did you see this discrepancy? It's clearly a '78, since your Jeep is a '78 model.'84 J10
'71 J4000
'14 Mustang GT
'20 Jeep Gladiator S
'84 J10
'71 J4000
'14 Mustang GT
