Old 06-03-2021, 07:13 PM
79 Wolfpack 79 Wolfpack is offline
Adjusting travel out of hydraulic lifter plunger
What are all your thoughts on adjusting travel out of the hydraulic Lifters.
I put together a 360 mode 2 engine with 343 pistons and 79 big chamber heads.
I installed some Harland sharp rockers for bridged heads and was thinking about adjusting travel out of the lifters
79 Cherokee wt
AMC high compression 401
t18 4speed
74 Cherokee nt plow
360 th400
Old 06-08-2021, 11:20 AM
SC/397's Avatar
SC/397 SC/397 is offline
Why?
Old 06-08-2021, 06:58 PM
Yeah, why? looking to make a solid lift set up?
Old 06-09-2021, 09:50 AM
Why ?
It is suggested in the AMC book performance America style For a mode 2 engine.
During long high rpm use the hydraulic lifters can get aerated oil and lose lift.
The lifters I bought have a lot of plunger travel . If I set them up with normal preload . It almost seems like the pushrods could fall out if the lifters oil drained back after sitting over night or a few days on cold start up .
I should have bought better quality low travel hydraulic lifters.
The only reason why not I know of would be if the lifter got pumper up from accidentally floating the valves . The pistons could hit a valve.
79 Cherokee wt
t18 4speed
74 Cherokee nt plow
360 th400
Old 06-09-2021, 10:03 AM
SC/397's Avatar
What do you consider, Long and Hi RPM use?
Which oil filter are you using? A poor quality oil filter will leak down over night resulting in rattle on start up.
Old 06-09-2021, 08:37 PM
4000 - 5500 rpm for 30 minutes to an hour .
I have used many different filters.
Baldwin b9
Motor craft
Wicks
Napa
Currently I have been using carquest filters the guy told me they are made by
Baldwin.
79 Cherokee wt
t18 4speed
74 Cherokee nt plow
360 th400
Old 06-12-2021, 09:48 AM
What are you using this motor in to run at that rpm for an hour?
Old 06-13-2021, 08:22 AM
Amc powered jet boat
79 Cherokee wt
t18 4speed
74 Cherokee nt plow
360 th400
Old 06-14-2021, 04:29 AM
I would suggest a solid type set up then but pay close attention to your oiling system and temp, that will be a lot of load on the engine at that rpm but if set up right should work.
Manual Window Lifter Install Dmntxn77 Other 2 11-30-2012 10:59 PM
Lifter Preload Questions and Answers Wagoncrzy Engine 7 06-26-2007 10:03 PM
Help!!! Valve lash now with pic Wagoncrzy General FSJ Tech 2 06-23-2007 06:41 PM
Ouray Reservations/Convoy's Posted Here!!! Updated 08/9 irbob General FSJ Tech 2 08-09-2002 05:19 PM
