Old 09-14-2002, 11:22 PM
Rat Rat is offline
Question
Has anybody ever run into two different wheel bearings being used on the same axle?I started out replacing a broken wheel stud on the drivers side and figured "Since I'm in here"I'll replace the wheel bearings.When I tore it down the actual bearings and races were not what was supposed to be in there.The inner race was larger with a small bearing.DSPO!!!!That was two weeks ago.I ordered the matching Bearings and races for the inner and went to install them and all went well till I removed the pass.side and found it had the correct size for the axle so back to the parts store.I now have a spare inner for the drivers side.It appears that a D-44 outer was installed on the D-27.Is that acommon swap? Sorry this ran on.
70 Wag /350 Buick TH400 D20<br />Never Straight But Always Forward
Old 09-15-2002, 03:07 PM
Jeep Doctor
It can happen. They even used two different size spindle sizes for the D44's over the years, and over time, swaps happen.
Old 09-15-2002, 04:34 PM
Rat Rat is offline
Thanks for the info.I guess jeep did'nt do anything standard.
Old 09-16-2002, 03:14 AM
blt2krl's Avatar
blt2krl blt2krl is offline
Rat that is an understament.
Paul Hartman
79 waggoneer
AMC360/TH-400/203/205
www.cbioffroadfab.com
WWW.PLANET4X4.NET
Old 09-16-2002, 05:42 PM
Rat Rat is offline
I think I remember telling my wife the Jeep would be easier to find parts for than the Scouts.OOPS
[ September 16, 2002, 11:43 PM: Message edited by: Rat ]
Old 09-17-2002, 12:42 AM
trickc's Avatar
trickc trickc is offline
You sure you don't have my old cherokee??
I know for sure I did the same kind of swap on the front 44 of it cause one of the spindles was toast but I needed it back on the road asap and had another good one laying around, just used different bearings.
73 j-4000 "buttercup"-SOA 36's 4 door cab
78 wagoneer choptop-SOA 36's, 6 point cage, blah blah blah
