Old 04-23-2007, 01:37 PM
Donzi's Avatar
Donzi Donzi is offline
Welded axles + hydro-assist with qt offroad??
Anybody run welded or fully locked axles and hydro-assist with the qt in normal drive offroad? Just curious if its possible without trashing the cones. I ran my last case with this setup but it had a part-time kit.
I was thinking it might help with the turning radius by being in normal drive by transfering power to front during a turn (tighter radius should slip first etc...)...any thoughts...
Old 04-23-2007, 05:11 PM
Desert Beast's Avatar
Desert Beast Desert Beast is offline
360 AMC
not sure about the q-track, but i can tell you that if your welded in the front, doesnt matter if its engaged or not, it will still have crappy turning radius. as long as the 2 front wheels are locked together the radius will suffer.
but thats what front digs are for.
Old 04-23-2007, 06:30 PM
BRUTUS's Avatar
BRUTUS BRUTUS is offline
Why did you do that front dig when we left the meeting spot on steelbender? it wasn't that sharp of a turn?
Old 04-24-2007, 12:09 AM
360 AMC
because i can, because i can.
Old 04-24-2007, 08:46 AM
Sambo's Avatar
Sambo Sambo is offline
yes i did,and had no troubles! also my buddy angel campos did this in his wag without any hitches!
77 chero DEAD.
