Old 07-24-2022, 05:24 PM
Screeching belts!
My belts have always been screechy in my FSJs - mainly when the motor gets wicked hot and sits for a minutes. On restart they will scream until I blip the throttle. Have wirebrushed the pulleys to deglaze, use a crowbar on the alt to try and get all the tension possible on it.
That it's happened in two different rigs makes me think it's me. It didn't happen in an '84 I had 20 years ago though. Any tips?
1984 GW
360
Comp 260H
Harland Sharp Roller Rockers
Wiseco -21cc Forged Pistons
Performer Intake
Holley SA 670
MSD 8523
Dakota Digital custom cluster
Serehill headlamp harness
NWMP aux tank
1987 GW deceased
...but the parts live on
Old 07-24-2022, 05:46 PM
devildog80's Avatar
devildog80 devildog80 is offline
Perhaps a different brand of belts?
'81 CJ5 Base, 258 I6, MC2100, T176 4 spd, 300 TC, D30 Front NT, 3.31, 2-Piece AMC 20 rear NT, 3.31, 4" high arc spring lift
'84 Grand Wagoneer, 401 V8 (.030 over), MC2150 HA Comp, 727 auto, Selec-trac NP229, AMC 20 REAR - D44 FRONT - WT 3.31, 4" high arc spring lift
Rather be driving, than waiting to be modified
Old 07-29-2022, 06:06 PM
Theodore Theodore is offline
I had the squealing problem for quite a while; finally got a belt tension gauge & saw that I wasnt putting near enough tension on the belts. Power steering pump on my 90 GW takes 130 lbs, and alternator/A/C belts take 65/ea. Also, I was missing the belt tensioner on the power steering pump - fortunately I was able to find one at the junkyard. Havent had the squealing problem since.
Gates 91107 Belt Tension Gauge
https://www.amazon.com/Gates-91107-B...e%2C143&sr=1-1
Old 08-01-2022, 10:41 AM
That's almost as good sounding as Screeching Weasel!
Mine were silent when I had V-Belts. Then they screamed for a while when I had a serpentine kit. When I sold my truck they were silent for a the last 2 years or so. HOWEVER DO NOT thing a serpentine kit is a good fix. Please, do not even consider it.
00 Baby Cherokee
Old 08-28-2022, 09:13 AM
If any antifreeze or oil gets on the belts and pulleys, then they will slip and squeal. If I am doing a job that might get coolant on the pulleys, then I remove the belts first and I wash off the pulleys afterwards. I may also clean the pulleys with brake cleaner, then put new belts on if they were squealing before that job. The belt should be soft and flexible. Replace if the rubber is dry or cracked. If reusing belts, then I clean them with warm water and a little liquid dish detergent, then rinse off well. Over tightening a belt will eventually cause bearing failure on the involved components. Too loose and they will slip. I have found that belt dressing did not work for long, I have tried both liquid and spray on.
Dave
Old 08-30-2022, 08:40 AM
All good stuff here! Will try giving the PS pump more tension, because there is no way that the alt can get tighter. Man that thing is tricky to tension!
1984 GW
360
Comp 260H
Performer Intake
Holley SA 670
MSD 8523
NWMP aux tank
1987 GW deceased
Seat belts from the 70's just don't work dkmcgowan General FSJ Tech 10 11-05-2012 04:32 PM
Need help retrofitting shoulder belts Tigger4X General FSJ Tech 4 06-15-2011 06:52 PM
Squeeky belts + Bar of soap -- WTH?! Elwoody General FSJ Tech 6 03-05-2011 08:47 AM
Replacement Seat Belts - Now with Pics! zmjeeps General FSJ Discussion 39 09-28-2009 07:10 AM
cs-144 upgrade (Belts for pulley??) Wagoneerlover General FSJ Tech 12 01-05-2007 03:11 PM
