Old 07-16-2022, 03:59 AM
stonybrookpictures's Avatar
stonybrookpictures stonybrookpictures is offline
Replace chain while case is in?
I am replacing my chain hopefully this week.
Is it better to remove the case, or leave it in and work from under the truck?
Providence RI
1979 Wagoneer 6" Lift, 35" tires. AMC 401.
Old 07-16-2022, 09:02 AM
I'd do it under the truck.
Old 07-17-2022, 06:33 PM
OK
As it is written
So it shall be
Providence RI
Old 07-17-2022, 06:46 PM
Cliff's Avatar
Cliff Cliff is offline
Very easy to do with the case installed.
Cliff Danley
1977 Cherokee S
Old 08-04-2022, 10:24 AM
Yes! Much easier in the truck. The service manual write up is good but The Mile Marker Conversion instructions are better. Obviously you stop after you remove the chain, then install the chain. If you jack up the back of the truck, you can comfortably sit on the ground with your head up and not drop stuff in your eyes. Also, I think 79 is the only year that had a giant seal around the two case halves. If there is no seal, you just RTV it shut.
https://jubileejeeps.org/quadratrac/mm_instructions.pdf
00 Baby Cherokee
Transfer Case '89 GW - Eliminate? ITLBOK333 General FSJ Tech 3 01-24-2012 09:39 AM
Must replace Yoke on NP208 transfer case caionneach General FSJ Tech 5 05-27-2011 12:48 PM
Quadratrack Case Noise ? BURT General FSJ Tech 13 09-14-2006 09:34 PM
What are the symptoms of a slipping x-fer case chain? waggin'ear General FSJ Tech 1 05-23-2001 06:09 AM
