Old 02-13-2018, 04:58 PM
rayray311's Avatar
rayray311 rayray311 is offline
Interior door panels
Hey All
My driver door interior panel is shot...whats best place to find replacements?
I drive a 88 Grand Wagoneer
Also....are there good websites for aftermarket wagoneers? Im new to these...I used to drive XJs.
Old 02-13-2018, 06:32 PM
Tripwire's Avatar
Tripwire Tripwire is offline
Wanted section for OEM?
FSJK - did not think of BJ's...thanks
Abort? Retry? Ignore? >
Old 02-13-2018, 06:49 PM
FSJK FSJK is offline
http://www.bjsoffroad.com/Upholstere...ls_p_1997.html
Old 02-13-2018, 10:26 PM
nograin's Avatar
nograin nograin is offline
Men in Black makes the panel boards. See the Classified section, Homegrown venders; at the bottom select show posts "from the beginning".
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
Old 02-14-2018, 10:54 AM
rayray311's Avatar
HOLY SMOKES...$250
Just Empty Every Pocket standing up to its name with this replacement part
Old 02-14-2018, 10:56 AM
rayray311's Avatar
I googled men in black jeep parts etc...no such site I could find
Old 02-14-2018, 11:37 AM
SJTD SJTD is offline
Don't bother with Google. Follow the directions given. He's got a thread on this site in the Vendor's Forum.
Sic friatur crustulum
Old 02-14-2018, 11:48 AM
Crankyolman's Avatar
http://www.ifsja.org/forums/vb/showthread.php?t=125368
Old 02-14-2018, 03:34 PM
rayray311's Avatar
Talking
Originally Posted by Crankyolman
ooohhhhhh on this site LOL
thanx bud.
Old 02-26-2018, 07:39 PM
Alys4x4 Alys4x4 is offline
Noob!
I bought the panels from MIB..highly recommend them they were great
Old 02-26-2018, 08:24 PM
HOLY SMOKES...$250
What did you expect? The smaller the market, the more replacement parts will cost. Ford sold nearly a million light trucks a year. Jeep, maybe 1/50th of that, depending on the year. Completeness adds a lot of value to these vehicles. I would look to used parts, if the aftermarket replacement parts are too expensive.
Old 02-28-2018, 11:17 AM
rayray311's Avatar
when you guys use the aftermarket panels by MIB have any of you then reupholstered them? My driver door underneath panel is all waterlogged and shot so the abs one would be awesome...but also on my original the carpeting along the bottom is all tattered and frayed and needs to be replaced I think.
Anyone ever find a way to redo this yourself? Any ideas welcome
Id hate to just have the abs panel on my driver door while all my other interior doors are original and in good condition.
Old 02-28-2018, 11:33 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
an upholstery shop may be able to transfer your OEM upholstery onto the new ABS board, and use new carpet at base to get rid of the water damaged part.
you can find decent used OEM panels on ebay sometimes
or check with watson and sons jeep salvage in pinetown, NC
( they ship and they are honest )
P.S. in fact on ebay someone has upper vinyl upholstery
for tan door panels that look great, if wrong color, clean well and dye with S.E.M. vinyl dye or equally good product, then attach to new board.
dave in NC
Old 02-28-2018, 03:26 PM
rayray311's Avatar
Thumbs up
dave in NC
Thanks for the info
Old 03-01-2018, 07:18 AM
mdcptman's Avatar
mdcptman mdcptman is offline
Jeep Therapist
What color do you need? I have a good Sand color drivers panel. Vinyl is good. Board is a little water damaged, but very usable for daily driver. Pm me ur number and ill send pics. Ill sell it for $50 plus the shipping.
88 Grand Wagoneer
360/727/NP208/dana 3.31s
Edelbrock 2131
Holley 600
Hydroboost
Hedman headers
Dual exhaust
MSD6A, TFI
Digital Gauges
Rusty's 2" Lift
31x10.5 15LT15s
Quote From Friend's Mom:
Old 03-04-2018, 09:24 PM
letank's Avatar
letank letank is offline
if it is not too badly rotten you can glue another layer of carboard, cut a larger piece to cover the damaged area -yes by the speaker in my case-, I am testing this with different types of cardboard box, one has a side that is glazed -shiny- seems like a better option is water makes it way inside the door panel. I used yellow wood glue, water based and it is holding fairly well, I even put a coat of glue as it seems to create a varnish coat.
but make sure that the vapor barrier is still present, the plastic sheeting between the door frame/metal and the door panel
and that your window wipes are doing the job of keeping the water out of the inside door, which has drains front and rear at the bottom of the door, the newer FSJ had some mesh which can be plugged with debris and no drainage will occur.
Have fun
Michel
Old 03-07-2018, 11:49 AM
letank's Avatar
Adding some horror pict for the quick repair (read inexpensive)
Door panel installed yesterday, will see how it faires when I have to remove it
As found
a little bit of coaxing to bend the cardboard, I put a 2X4 not pictured
Then glued pieces to reinforce the creased areas
I added a small trim on the forward section to reinforce the clips holding wells
Michel
Old 03-07-2018, 12:02 PM
ZackN920's Avatar
ZackN920 ZackN920 is offline
Hey All
I drive a 88 Grand Wagoneer.
Did ya ever try any local junkyards? Door panels aren't a typical part that "goes bad" so you should be able to find something for cheap, if any yards in your area have GW's in them.
1990 Grand Wagoneer-"Big Jeep"
...not too rusty anymore
Old 03-07-2018, 12:20 PM
rayray311's Avatar
As found
Looks like a project!
Old 03-07-2018, 12:21 PM
rayray311's Avatar
Met someone on here that's gonna sell me one...also looking into local upholstery shops to help me fix some problems on my other doors
