View Poll Results: New windshield gasket?
Absolutely yes! 21 80.77%
Yes, because you can... 2 7.69%
No, reuse the old if it's good. 3 11.54%
Voters: 26. You may not vote on this poll
Old 03-29-2017, 12:52 PM
BA_051 BA_051 is offline
Replacing windshield
Well I recently had my windshield replaced (actually on March 27th, 2 days prior this posting) and the damn thing leaks, bad... before it was just in the lower corners, it now I literally have streams down the inside of the windshield... I live in Everett so i see 20+ inches of rain annually...
Now the question... new gasket or reuse the old? The tech (claimed he has done a lot of pinch type windshield gaskets, and about 50ish) said mine was still good and new ones take years to relax and it will leak from day one... so he reused my old one... the shop can get a new gasket, but they are reluctant to do so...
I owned it for the past 18 years so I know it hasent been done in that time, but not sure if it was replaced before then. The old glass did not have the blue shade on the top...
1974 Jeep J20, gladiator grill, 6BTA JWAC cummins, HX55, 4in exhaust to 5in stack, nv4500/ford np205, 14b kingpin axle, 14b rear axle, 4.56 gears, 40x13.50r17's on 17x10 mags
Future mods:
G56 6 speed with dual disk clutch
Vintage air AC and Heat underdash combo unit
Old 03-29-2017, 01:03 PM
I got one done by Safelite who said my old gasket was good to re-use. It also leaked from day one. When I had them come out to fix it they would not honor the warranty since it wasn't their gasket. I recently had another windshield installed by a local guy in Oak Harbor, WA with new gasket. Does not leak a drop, even in the soggy PNW.
And despite what many say, the windshield DOES REQUIRE SEALER. Many shops think that just the gasket is enough. It says right in the 1979 FACTORY TSM in plain writing to use a sealer around both sides of the gasket.
-Jonny B.
AMC 401 - Pro-Flo 4 EFI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 03-29-2017, 01:04 PM
I have installed five or six FSJ windshields in the past all using the original gasket, none of them have leaked. I always insert a small bead of butyl inside the channel that the glass goes in first. This makes installing the glass more of a challenge but the don't leak. Doing this on an extra warm day helps the installation but not the installer.
Resistance is not futile yet.
Old 03-29-2017, 02:54 PM
My 1 piece rear glass was leaking so I bought a new gasket and tinted the 4 piece rear while I had it apart and it hasent leaked a drop... I cleaned the body real good and the frame as well. I used sealer on both sides and after about an hour, it was in...
The shop spent about 1.5-2 hours to replace the windshield and I even told them not to put the trim back on... they forgot my mirror button (had to go buy that, $2) and broke my antenna ($8, whatever)... they gave me some BS story about well if it leaked before then there are no guarantees that it won't leak again... I am taking it back to them next Monday to redo it... they are probably just going to back fill it...
They made a nice big mess everywhere with the sealer too that I need to clean up... both on the glass and the body...
Future mods:
Old 03-30-2017, 10:34 AM
I'd go with the old gasket if the new one was too expensive at first but now you have a leak after professional?? installation.
Get a new gasket and some rubber butyl. take it to them and tell them to clean the crap out of it and use the rubber butyl this time and not make a mess. I'd have them remove it and personally check to see if they at least ran a brush around the rim to clean and remove all the old stuff the first time. And check for rust throughs.
Old 03-30-2017, 11:56 AM
mdcptman's Avatar
mdcptman mdcptman is offline
Jeep Therapist
I have an 88, and i replaced mine myself. 1st and only time. I used the old gasket, which I spent about 3 hours cleaning thoroughly. An old mechanic told me to use Pam cooking spray as lubricant, and butyl rope for sealer. I put it in, and it hasn't leaked at all. Maybe beginner's luck. Idk, But I'm a believer in the Pam and Butyl. I have heard that the new windshields are thinner? I used one I picked from a GW in a junkyard. so that may be a factor also. You might try unlocking the gasket, and trying to slip some sort of sealer between the glass/metal and rubber on the outside, then locking it back.
88 Grand Wagoneer
360/727/NP208/dana 3.31s
Edelbrock 2131
Holley 600
Hydroboost
Hedman headers
Dual exhaust
MSD6A, TFI
Digital Gauges
Rusty's 2" Lift
31x10.5 15LT15s
Quote From Friend's Mom:
Old 03-30-2017, 04:02 PM
A new gasket is not that expensive or hard to find. I don't understand why you wouldn't use a new gasket... even if it doesn't leak now, its an old piece of rubber and is going to dry/crack at some point... It just seems like a bit of a gamble to re-use the old one.
00 Baby Cherokee
Old 03-30-2017, 04:33 PM
Yea cost isn't an issue, but I don't want a cheap pos either. I'll be around Tacoma on Monday so I figured I'll stop by BJs and pick one up. I hear theirs are good. TGW are to long on the bottom and others are pos's, so I have heard.
There isn't no rust on the body flange for the windshield, I looked at it personally when they did it but they wouldn't let Me watch them install. They probably didn't clean it well enough... I will have them yank it and use a new gasket, clean the windshield from all sealer, and make sure they clean the body flange as well...
So gasket and butyl sealant... I'll ask them if that's what they use...
I work 72-84 hours a week (6-7 12hr shifts) hence why I paid someone to do it professionally... I just do not have the time or helping hands to do it...
Future mods:
Windshield wiper chatter... at my wit's end iroc86 General FSJ Tech 14 02-15-2012 03:08 PM
Windshield instalation rusty eagle General FSJ Tech 10 06-25-2010 07:59 AM
Approximate cost for removal and reseal of windshield twmattox General FSJ Tech 7 03-23-2010 11:22 AM
REMOVING WINDSHIELD AND REPLACING?? Duckman General FSJ Tech 15 05-31-2002 03:33 PM
