Old 02-13-2017, 08:56 AM
mdcptman's Avatar
mdcptman mdcptman is offline
Jeep Therapist
Oil leaking around intake bolts?
Has anyone had the problem of oil pooling around the intake manifold bolts on a 360 with an Edelbrock 2131? I've noticed it since i changed the intake, and my current strategy of just ignoring it has proven ineffective. Should I put some RTV on the bolts? Should I put it on the threads or just under the heads?
Also, you Holley experts, What is the thing my finger is pointing at do?
88 Grand Wagoneer
360/727/NP208/dana 3.31s
Edelbrock 2131
Holley 600
Hydroboost
Hedman headers
Dual exhaust
MSD6A, TFI
Digital Gauges
Rusty's 2" Lift
31x10.5 15LT15s
Quote From Friend's Mom:
Old 02-13-2017, 09:07 PM
mdcptman's Avatar
Jeep Therapist
Anybody?
88 Grand Wagoneer
Edelbrock 2131
Holley 600
Hydroboost
Hedman headers
Dual exhaust
MSD6A, TFI
Digital Gauges
Rusty's 2" Lift
31x10.5 15LT15s
Old 02-14-2017, 11:36 AM
Heep-J4000's Avatar
My 73'J4000 always has a oil puddle on that same area of the intake manifold
It has a motocraft 2150 on and is converted to LPG ,so it has nothing to do with the carb i guess!?
And the thing your finger is pointing at ,could be something from the chock mechanism?
73' Jeep J4000 (named Heep or Desert Dragon) amc 360 V8 converted to LPG with T15/D20 (was my daily work truck for thirteen years and is getting major overhaul at the moment!)
80' Jeep cj5 350 V8 Chevy/sm420/D300 project
70/71 Jeep J4000 parts truck with Buick 350
Former vehicles:
Old 02-14-2017, 08:59 PM
I believe you are pointing @ what holley calls a ford kickdown lever.
It's not needed in a Jeep.
Old 02-14-2017, 10:51 PM
You could try pulling the bolts one at a time , cleaning them up and putting sealer on them. it's not going to hurt anything.
Old 02-14-2017, 11:34 PM
78basicwag's Avatar
78basicwag 78basicwag is offline
Mine also leaks, it's a stock 360 manifold. I tried to torque it but still leaks.
Old 02-15-2017, 08:55 AM
Whats leaking exactly though? The intake is under vacuum, so it shouldn't be coming from the valley, correct?
Are the bolts threaded in a dead hole or do they see oil pressure for some reason?
2004 Jeep Liberty
1998 Jeep ZJ 5.9
1994 Jeep ZJ I6
1989 Jeep Grand Wagoneer 360
Old 02-15-2017, 10:18 AM
twmattox twmattox is offline
I have seen valve covers leak down and fill those valleys. Odd though, it usually leaves a trail...
Old 02-15-2017, 10:44 AM
68glad's Avatar
68glad 68glad is offline
Mine did that too yrs ago. No idea why. Hi temp silicone fixed it
68 gladiator- 455/400/20 r.i.p.
78 wagoneer- 401, drw60, drw70, 203/205, 38's, oba, obw, hydroboost, dual p/s pump, bla bla bla
Old 02-15-2017, 09:15 PM
I'd have to look at a set of heads but I don't think they're blind holes.
I can see how a bit of oil vapor might work up there but not a pool. you must be getting a lot of blow by ?
Old 02-15-2017, 10:34 PM
mdcptman's Avatar
Jeep Therapist
I am getting lots of blow by. So maybe I should start w the pvc valve...
88 Grand Wagoneer
Edelbrock 2131
Holley 600
Hydroboost
Hedman headers
Dual exhaust
MSD6A, TFI
Digital Gauges
Rusty's 2" Lift
31x10.5 15LT15s
Old 02-15-2017, 10:42 PM
PCV can only handle so much, you might check your breather cap to make sure you're not building a little pressure.
Old 02-16-2017, 11:29 PM
mdcptman's Avatar
Jeep Therapist
I don't think the cap is an issue. I'm getting blow by into the air filter. Guess a ring job is in my future.
88 Grand Wagoneer
Edelbrock 2131
Holley 600
Hydroboost
Hedman headers
Dual exhaust
MSD6A, TFI
Digital Gauges
Rusty's 2" Lift
31x10.5 15LT15s
oil coming out intake bolts jlewis General FSJ Tech 9 07-24-2013 07:57 PM
Easy intake install...for a change Rich88 General FSJ Discussion 7 11-11-2012 07:58 PM
Leaking front seal on intake Terry Buege General FSJ Tech 1 06-12-2006 09:08 AM
Intake Manifold Bolts JAllenWAG General FSJ Tech 13 03-22-2004 02:19 PM
Intake and Carb Upgrade Michael General FSJ Tech 6 10-05-2001 03:10 AM
