Old 09-27-2016, 07:22 AM
Donzi's Avatar
Donzi Donzi is offline
76' Cherokee towing capacity
Hi Guys,
Im in the process of registering my 786' cherokee in Sweden and they want some kind of paper stating what the towing capacity is of the jeep. Does anyone have a factory manual or similar that has this info? Can you snap a pic or post a file showing the data?
Thanks!!
Jeffrey
Old 09-27-2016, 09:17 PM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
The factory approved trailer tow rating depended on the engine, drivetrain, suspension, axle ratio, other options.
It varied anywhere from 2000 pounds to 7500 pounds.
Old 09-27-2016, 11:03 PM
Ghinmi's Avatar
Ghinmi Ghinmi is offline
Super Moderator
Here is what you are after. It's in the 1976 Jeep brochure.
Old 09-28-2016, 08:18 PM
Donzi's Avatar
Thanks! Do you know if there is another version for a T-15a /D20 combo?
Old 09-28-2016, 09:30 PM
FSJunkie's Avatar
T-15 is a 3-speed transmission. That will likely limit you to 3500 pounds factory rating because the 4-speed trans and the automatics gave you quite a bit more torque multiplication at low speed to get a heavy trailer rolling.
Old 09-28-2016, 11:25 PM
Ghinmi's Avatar
Super Moderator
Unfortunately, without an automatic I don't think you're going to find any factory paperwork that recommends towing.
Old 09-30-2016, 11:05 PM
FSJunkie's Avatar
My 1973 towing pamphlet shows the manual transmissions being rated for 3500 pounds trailer weight. Any trailer heavier than that they specify the automatic transmission.
I wouldn't be afraid to tow above 3500 pounds (likely no more than 5000) with a manual transmission so long as it was a 4-speed and had a good deep axle ratio. This is where a 'granny gear" 1st comes in handy. A 3-speed will not have as deep of a first gear to get a heavy load rolling.
Old 10-04-2016, 08:17 AM
Ghinmi's Avatar
Super Moderator
I don't know if you read his actual post or not but he's looking for Jeep paperwork for his year to submit for registration. Not something from a different year followed by someone's random thoughts.
Old 10-04-2016, 11:42 AM
Jeffery, I've got an original 76 Jeep sales brochure which has the info Ghinmi posted in his reply. If a factory sales brochure will help with the registration process, PM me and I can airmail it for the cost of postage.
Old 10-04-2016, 03:37 PM
FSJunkie's Avatar
Yeah, I'm pretty dang sure I read it but thanks for checking in on me.
Bent Axle :( , need help with spec's mdill General FSJ Tech 6 05-25-2010 05:08 PM
Azusa off-road videos, pics, and Cherokee review PlasticBoob General FSJ Discussion 12 10-23-2007 05:48 PM
Yellow NT Cherokee towing RX-7 in Fountain Valley yesterday...anyone here? PlasticBoob General FSJ Discussion 0 09-23-2007 04:44 PM
Towing Cherokee missionpilot General FSJ Tech 7 10-24-2005 03:06 AM
1981 Cherokee Laredo - Tom Anhalt Dome Cherokees 0 08-21-2005 12:36 PM
