Old 10-24-2011, 12:25 PM
catch2otwo catch2otwo is offline
brake light switch
When i step on the brakes in my 72 wag the brake lights do not illuminate. I looked at the brake pedal assembly and didnt see any kind of push button switch. I see two wires coming out of the bottom of the master cylinder. Is that some kind of pressure/hydraulic switch for the brake lights?
1972 Wag
Buildthread
Old 10-24-2011, 12:30 PM
mattywilz's Avatar
mattywilz mattywilz is offline
Take a look at your master cylinder, there should be a hydraulic switch threaded into the underside of it. You will have to bleed your brakes if you replace it.
Matt W
1970 J-2000 Buick 350/D20/T-15/D44s/4.09
1985 Grand Wagoneer 360/NP229/TF727/D44.AMC20/3.31
Old 10-24-2011, 01:21 PM
Thats exactly what I thought that was. Do these usually go bad?
1972 Wag
Buildthread
Old 10-24-2011, 01:43 PM
oldyellowwagoneer oldyellowwagoneer is offline
Probably the factory switch so I guess they don't go out too often.LOL
“Don't do anything by half. If you love someone, love them with all your soul. When you go to work, work your *** off. When you hate someone, hate them until it hurts.” Henry Rollins
Old 10-24-2011, 01:55 PM
In forty years? Yes. Changing brake fluid yearly as you should goes a long way to making the hyd parts last.
Old 10-25-2011, 09:10 AM
lkmarsh's Avatar
lkmarsh lkmarsh is offline
My 69 had the same MC brake light switch. When it gave up, it not only leaked brake fluid, it let air into the MC. Plugged the hole and mounted a switch on the pedal, where it belongs. One example of bad design creating a completely unnecessary safety risk.
Lyle
68 Chevelle wagon 350/BWT50
68 Impala wagon 327/400
04 Impala LS - Wife's DD
73 Wagoneer parts donor
Old 10-25-2011, 08:27 PM
Any picture of the switch you used?
1972 Wag
Buildthread
Old 10-25-2011, 09:22 PM
blakeusa's Avatar
blakeusa blakeusa is offline
Just test the switch first using a test light - as it could easily be a bad ground or break in the wire or connector. It's a 2 wire switch and are used on many GM cars. Cheap part buy messy to replace.
I would remove the 2 wires bullet style connectors, clean the contacts and test first.
1971 J4000 Gladiator w/AMC 401 Restoration Project
Old 10-26-2011, 07:39 AM
Wow brain fart, I just realized that since my wheel cylinder has been leaking, my mc is empty. And since the switch is a pressure switch, there would be no pressure on the switch. I was just about to ask how to test it, and put 2 and 2 together.
1972 Wag
Buildthread
Old 10-26-2011, 07:46 AM
Revhendo's Avatar
Revhendo Revhendo is offline
Don't need a test light, the truck is already equiped with one. Just touch the two wires together and see if the brakelights come on.
Oh, and the pressure switch is more of a Ford deal. General Mayhem has been using pedal mounted switches for over 60 years.
Rev.
OK, who put the magnet under my moral compass?
1988 Grand Wagoneer. Going for the ultimate fishing rig.
I named her Tinkerbell after my cat. She always demands my attention and whenever I show her love, I come away bloody.
Old 10-26-2011, 07:50 AM
I will try connecting them two to see if I get power through the wire. Thanks
1972 Wag
Buildthread
Old 10-30-2011, 08:12 PM
OK so I unplugged both wires coming from the MC pressure switch. Connected them together. Put my test light on the wire and got nothing. To confirm, I turned on the headlights and the same wire became live.
Did I do something wrong or is my wiring fubard? My friend said the brake lights worked when he parked it so whats my next step? I looked at my jeep service manual but there was no wiring schematic.
1972 Wag
Buildthread
Brake Idiot light keeps going on and off intermittantly beloth Off-Road FSJ Tech 8 01-31-2009 06:53 PM
t400 b/u light switch Slim General FSJ Tech 2 12-19-2006 12:13 PM
Where is the brake light sending unit on a J-4000? rampagefsj General FSJ Tech 15 09-10-2006 05:52 PM
Brake Light Switch on bottom of master cylinder -- 1972 Wagon marmoset General FSJ Tech 4 09-09-2003 02:26 PM
Brake warning light won't go off RWC General FSJ Tech 4 09-02-2002 02:01 PM
