Old 10-17-2011, 10:25 AM
Blake Blake is offline
Who has actually ran a Holley TA 470 on an AMC V8?
I'm about to pull the trigger on a brand new Holley TA for the waggy and was wondering if anyone has actually ran the 470 at altitude? If so, any regrets? How does it run? What jets are you running?
I already have a Holley TA 670 on the J10 and feel that it's a little big.
Old 10-17-2011, 11:15 AM
jeepjseries's Avatar
jeepjseries jeepjseries is offline
Unless your 360 is built go with the smaller TA carburetor.
-2000 Volkswagen Jetta diesel
-1976 Wagoneer 401/Turbo 400/QT with 4 low/Dana 44s
Old 10-17-2011, 06:30 PM
Gambler68's Avatar
Rabble Rouser
Awaiting results, I'm thinking that's the right size for playing at HA.
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 10-17-2011, 06:53 PM
Well the CFM chart says a 470 will be ok.
I dunno.
I'm probably gonna get one in less than a week. Thinking about putting it on the J10 which already has a good running 670 and comparing the results.
Something tells me the smaller 470 will be perfect. I don't hot rod the jeeps, I just want them to run well on the low end.
Old 10-17-2011, 07:56 PM
I brought this up A while ago and was told the 470 would be fine for a stock 360. Unless your bored out .30 over or other performance mods I would use it.
Old 10-18-2011, 08:08 AM
derf's Avatar
derf derf is offline
360 AMC
The overbore won't make that much of a difference.
The camshaft, intake and exhaust would. With an Edelbrock performer and a stock style cam, a 470 will be enough. You may lose a little on the top end but most people never drive at that high of an RPM so it's never really an issue.
If you start opening things up with an aggressive high RPM cam, a free flowing intake and bigger exhaust, the 470 will be a limiting factor. But these kinds of aggressive mods are really only for when you're planning on racing the 360 in something.
I'd love to see a 570cfm TA. It would be great for keeping the low end throttle response but allow for a little better breathing when the truck is really loaded down running at higher RPMs (like when you're towing a load up a long grade). But Holley doesn't make one.
Try out my gear ratio calculator
Old 10-18-2011, 05:31 PM
Stuka's Avatar
Stuka Stuka is offline
Your are over carbed with a 670cfm carb. The engine would need to be running far more RPM than most of us would ever even consider running them. And even if you had a lot of mods to get the VE to be higher, you still arent going to need it.
I actually felt I was a bit over carbed with an edelbrock 600. I needed to be at around 5500rpm to go WOT and have it run properly.
470 would be a little on the small side for WOT 5500rpm use. But its bigger than the stock 2v that they came with, and those smaller primaries will be great for low rpm throttle response.
Old 10-19-2011, 12:55 AM
5500 rpm's? I think either of my AMC v8's would blow up before revving that high!
I'm almost ready to pull the trigger on the 470.
http://www.summitracing.com/parts/HLY-0-90470/
Old 10-19-2011, 06:45 AM
blake5179's Avatar
blake5179 blake5179 is offline
what do you guys think about this statement from Holley:
"This carburetor is not designed or intended for use on any V8 application. This carburetor is designed for extreme off-road, off-angle use. Due to its design, it is not recommended for street driving or towing applications because rich conditions and poor fuel economy will be experienced."
Not designed for use on a V8? Not recommended for street driving?
Will it still pass emissions testing?
I've thinking more and more about these Holleys but still not sure. I do need to be able to drive to the trails, I don't care about 5000+ RPM's but I really care about the Jeep not stalling on steep climbs and side hills.
1977 Cherokee
360 V8 T18 Manual Dana 20 TC
Lockers front and back
Warn 5721 winch
36" TSL's beadlocks
Holley Fuel Injection
Front manual hubs
SOA and SF
Old 10-19-2011, 08:21 AM
derf's Avatar
360 AMC
They want to sell you the bigger carburetor, which costs a few dollars more, and then sell you all the parts you need to tune it to where it runs right.
Old 10-19-2011, 10:40 AM
That's not really true.
The 470 and 670 costs the same.
I'm not sure they are trying to 'get us' on the parts either. They just made a very tunable carb for us to play with
I already know the offroad benefits to using these carbs as I already have one on the J10. I've read on here that the MC2150 is a good offroad carb. Well, maybe it is compared to other types of carbs, but it doesn't even compare to the TA. I was recenlty 'wheeling the waggy on some medium difficulty stuff and the MC2150 stalled out several times. Especially bouncing around and sudden starts or stops. Now there are those who could argue that I have the carb grossly miss-tuned, causing the stalling. Well if that is true, how was I able to pass emissions with it? On 35's?
I've already added it to the summit shopping cart and just waiting on payday to click 'purchase'.
I'll report on it's performance in my Goofy build thread.
Old 10-19-2011, 11:23 AM
Gambler68's Avatar
Rabble Rouser
With a 1406, Th400, QT, 360 with a Holley Street Dominator intake, and 33's, I can only hit 4k at 90-100mph. Or in 4-LO spinning the tires..either way, 5500 is lightyears beyond anything my jeep would approach.
Thank you Blake for spending the coin to get some real world results
Old 10-19-2011, 08:35 PM
billyj7175's Avatar
Doesn't apply to your crowd with the NV4500, but the stock 727 auto is governed at 4500 rpm anyways...
I had a thread similar to this a while back...and between the time of me finding it, researching and getting back with the guy, he realized what he had...oh well. However, I do plan on running a 470 anyways...just waiting on a good deal somewhere...
83 J-10 Jeep "Oscar"
360/727/229
Old 10-20-2011, 08:40 AM
derf's Avatar
360 AMC
It could be your float level in the 2150 is a tad too low. That would contribute to stalling off road while letting you pass emissions just fine.
But that doesn't necessarily mean anything. There is no empirical evidence to prove one way or another which carburetors are better than which. Just anecdotal evidence and that's not reliable.
Old 10-20-2011, 12:03 PM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
Legaleeze for if you put something of theirs on your car and something happens, they warned you and it's not their fault.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 10-20-2011, 06:31 PM
Stuka's Avatar
I had a T18a, so I could hit any RPM I wanted until the valves floated up until 3rd. With autos, they will make you shift before then unless you have a manual valve body.
As for them saying the 470 isn't for a V8, you will need to jet it most likely. But its still bigger than the stock 2150 carb.
The 470 would actually work pretty well on a well modded 258.
Old 10-21-2011, 11:30 AM
Well I was planning to get the TA 470 today, but something else came up, so I am holding off.
I am still looking to buy one, but not today.
Would love to hear from someone who actually has a 470 on a V8 though. Especially at high altitude...
Old 10-21-2011, 02:12 PM
Gambler68's Avatar
Rabble Rouser
Didn't think about the stick.
I've actually been considering a 470 for my 327 Vigilante..expensive experiment though. Likely I'll settle on a smaller carb that good for around my altitude locally at 6500 and do a TA on my trail rig.
Old 10-21-2011, 05:54 PM
GI-John's Avatar
GI-John GI-John is offline
I have a 470 TA on my Jeep. 76 Cherk with an 87 Motor. TH400/D20 Stock except for carburetor/Holley street dominator.
Low end grunt is great; I really don't get into it much but the power is smooth and consistent up to about 3500 rpm. The secondaries kick in smoothly, almost too smoothly. I DD this and haven't been off-road with it. I live in NJ, so no experience with altitude. Out of the box this carb was fantastic compared to the Holley 600 it replaced.
Hope this helps,
John
Just Emptying Every Pocket
Old 10-21-2011, 06:01 PM
Gambler68's Avatar
Rabble Rouser
With the small intake runners on the Street Dominator, that should be a great combo.
Hats off to Holley TINMAN93 Off-Road FSJ Tech 6 10-19-2011 08:32 PM
Holley replacement for MC2150 kevinator General FSJ Tech 18 09-07-2011 09:12 PM
I am looking for a holley R 3262! georgie General FSJ Tech 0 09-15-2008 05:46 PM
Partial Holley TBI Parts Interchange List Spectre Fuel Injection 13 07-14-2006 12:36 PM
HOLLEY 2150 REMAN CARB - A GREAT CARB WINGO General FSJ Tech 4 11-25-2001 12:36 PM
