Old 10-11-2011, 02:45 PM
Donzi's Avatar
Donzi Donzi is offline
Thinking about a new build...
It's been a while...but I finally got another FSJ...a 79' Chief.
Thinking about an LQ9/4l65/xxx on either volvo portals or a set of tons with 5.38's and 42ish Rockers on beadlocks. I have access to a full shop...or barn with lots of tools
My budget is about 7000.00...plus whatever parts I can sell off the truck that get replaced.
Goal is a road legal rig (sweden) that is just biatchin' and can be wheeled hard.
Is it too ambitious to try and squeeze in a Gen III+ drivetrain?
Anybody wanna share some good links for info or similar FSJ builds?
Old 10-12-2011, 10:38 AM
jeeping1974's Avatar
Those Portal axles are wicked cool. The down side is that a set of stockers will run you about $2500-$3000 in the US. I would think you could have a set of built 1 tons for that price, maybe cheaper.
The GenIII drivetrain is not out of the question though. As long as you (or if you have a good friend) are good with fabrication, you should be abel to build your jeep within your budget.
03 GMC 2500HD - DD/toy hauler
06 Street Glide - Cruiser
Old 10-21-2011, 02:02 PM
Hutcho's Avatar
Hutcho Hutcho is offline
Sorry, couldn't resist...
Formally known as "oilfieldtrash354"
"Grandpas" 1979 J-10 resto/mod-on hold for now
Preparing for Ouray 2013!!!!
Old 10-21-2011, 05:47 PM
Stuka's Avatar
Stuka Stuka is offline
Hey, long time no see man
Are you planning on a 4 link setup? Because portals with leaf springs really does not work well. Tons of axle wrap.
As for the engine, I assume you mean the L92? Good engine, lots of power. I don't think fitting the engine will be an issue. You will need new motor mounts, ad do some other changes, but the blocks are no larger than a SBC. So you should be fine.
Old 10-23-2011, 09:20 AM
Skeeter74 Skeeter74 is offline
[quote=Stuka]
As for the engine, I assume you mean the L92? .[/ quote]
The LQ9 is GMs 6.0 liter.
Originally Posted by Tatsadasayago
"And on the 7th day god created the Full Sized Jeep and he saw that it was good. He gave these mechanical marvels to his chosen ones and they went wheeling in style and comfort!"
80 Wagoneer Limited, 2 bbl 2150, 360, 727TF, NP219, "Moby Dick" Now with Dragonfire HEI, Contour dual fans, CS144,
Old 10-23-2011, 06:41 PM
Stuka's Avatar
[quote=Skeeter74]
Ahh yeah, it was the Gen III that came before the L92.
Old 10-25-2011, 12:42 PM
Donzi's Avatar
Thanks for the input guys
Yeah its been a while Stuka!
But I am leaning toward the LQ9...
I'll get some pics next week...
I was thinking about going spring under on the portals...but we'll see. I need to source some first...and that is proving difficult
Old 11-27-2011, 06:11 PM
kiharaikido kiharaikido is offline
Try this site. Mog axles should be easy enough to find. Good luck and if you do go with Mog axles, will you post your progress?
http://www.benzworld.org/forums/unimog/
I think i may have to build it to get it ! AMC-J/20 General FSJ Discussion 36 01-17-2010 01:13 AM
74 j10 build up jeeping1974 Off-Road FSJ Tech 232 05-12-2009 07:59 AM
Timex build... LTS06 General FSJ Tech 9 01-19-2008 05:30 PM
NEWBIE BUILD UP DARWIN General FSJ Discussion 42 04-24-2007 11:42 PM
Want to build a good hauler/daily driver out of a 2-door Pete M General FSJ Tech 5 03-20-2004 02:39 PM
