Old 01-01-2011, 07:28 PM
fsjparts fsjparts is offline
How to remove light switch?
70 wagoneer trying to remove the light switch in the dash. but no small screw on the bottom to remover the nob. How do you get it off without breaking it?
Old 01-01-2011, 07:34 PM
Reach under the dash a feel the main part of the switch, either on top or bottom of it in the middle is a button. Push the button and pull the knob and shaft out as a unit. Unscrew and remove the trim bezel and pull the switch out the back.
Old 01-01-2011, 07:36 PM
awsome thanks,
Old 01-01-2011, 10:27 PM
blakeusa's Avatar
blakeusa blakeusa is offline
To reinstall you need to push it back in and may need to wiggle around until it clicks back in.
Here is a pic of the secret button.
1971 J4000 Gladiator w/AMC 401 Restoration Project
Driving light switch location '88 GW? acefish12 General FSJ Tech 3 04-15-2010 07:19 AM
Change light knob to toggle switch londonhogfan General FSJ Tech 9 06-16-2007 04:04 PM
1972 Wagoneer -- turn light switch marmoset General FSJ Tech 5 10-23-2006 10:30 PM
odd light switch behavior elskeptico General FSJ Tech 8 05-16-2005 03:23 PM
reverse light switch? pb General FSJ Tech 1 10-06-2003 05:37 AM
