Old 02-10-2022, 07:23 AM
Bc409 Bc409 is offline
Fuel pump lifespan
What are opinions on why the v8 mechanical fuel pumps do not last long? I am an old guy have had rigs with pumps literally decades old that still work. Now my 78 wagoneer has had 2 go bad in less than a year. I am not a racer so do not need a robbmc pump. The tank has been cleaned, the filters are fine.did not really want to switch to electric but this is ridiculous.
Old 02-10-2022, 08:16 AM
inkedmonkey inkedmonkey is offline
That is weird. I've never had a problem with mechanical pumps. Can you try a different brand?
Old 02-10-2022, 08:30 AM
I had the same issue. I replaced 3 in 2 years--cheap Box store replacements. I believe Summit offers a performance replacement. However, I went to Holley Electric and havent had a Vapor-lock issue and easier starts over the past 7 years. Note: I draw a grnd wire from the battery and land it at the frame next to the pump. IMO, electric pump issues are related to bad connections.
Old 02-10-2022, 10:13 AM
today's new aftermarket parts are a sad sad joke!
especially anything that uses "rubber".
back in the day stuff lasted decades, now you're likely if it works out of the box.
the "rubber" they use today degrades incredibly fast.
Old 02-11-2022, 09:02 AM
nograin's Avatar
nograin nograin is offline
The one time I thought the pump was bad it was actually the rubber feed line.
So got almost 200,000 miles out of the original pump AFIAK.
The rebuilt engine has a new pump. So far no issues.
Thats my experience
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
Old 02-11-2022, 12:49 PM
timwiller's Avatar
timwiller timwiller is offline
ethanol is bad for cheap taiwanese rubber
1966 J-3600 Gladiator, 304 AMC, T-18/D-20 twin stick, D44/D53, custom mandrel bent magniflow exhaust
Old 02-11-2022, 06:06 PM
taking it out of the box is bad for cheapnese aftermarket crap
put a brand new pump on my dad's GW in MN ~10yrs ago.
he always used real gas
didn't last 6 months
2nd one worked longer
Carter Fuel Pump Install my experience KdkGrizz General FSJ Tech 5 07-29-2016 05:21 AM
42 Gallon Suburban Fuel Tank Installation (With more Pics!!!) Wagoneerlover General FSJ Tech 42 09-14-2010 08:34 PM
NO FUEL ....Bad fuel pump gear? thecountmc General FSJ Tech 5 02-01-2010 12:22 PM
I guess it's getting hot.... Belteshazzar General FSJ Tech 3 04-22-2009 10:02 PM
Upgrades/Tweaks to Improve MPG prayforsurf General FSJ Tech 33 01-04-2007 10:39 PM
