Old 08-23-2021, 12:00 PM
When is a rig "Built" not "Bought"
So I was cruising around SoCal yesterday and saw the stereotypical college girl Jeep (that's what my son calls this style; we've all seen it):
LEDS EVERYWHERE
polished aluminum 20" rims
scowling grill
A bright red high lift jack mounted in the most conspicuous place possible
Bright red D-rings on the front and back, clanging away as they drive
etc. etc. etc.
I think we all get license to do what we want with our rigs. College girl style is not my style but my style also isn't most other peoples style so set that aside, just setting the scene, I guess.
What made the one I was looking at pique my interest was on the back window it had a "Built not bought" sticker. So I started looking a little closer thinking maybe this one was a little different. I started looking at the undercarriage to see if there was any fabrication; None that I could see. Maybe gears and a locker were installed; rear diff cover looked like it had never been removed. I even saw what looked like stock JK Exhaust.
I started thinking "PSHHHH! Built??! What's 'built' on that?!" But the other side of me said "What's built about your turd? You just fix things that break. how is that anymore built than that JK?"
Hm... When I think "Built not Bought" my head goes 3 ways:
a) a ground up resto where everything came apart and went back together. Upgrades are irrelevant here. They got a starter vehicle and completely went through it.
b) A vehicle that was modified to do something that it was never really meant to do. So a Honda Civic that runs 10's in the quartermile. A rock crawling Wagoneer. A Baja bug. A Narrow Track Cherokee with a Hemi swap.
c) A car assembled from pretty much all new parts. So a Factory 5 Cobra Replica, Meyers Manx, a T-Bucket, a chopper.
But then again, maybe a vehicle that is generally modified by the owner should fit in here somewhere? At what point is it "built"?
What if the owner never really "built" it at all but bought a ton of expensive parts and paid a shop to install them? It was "built" by the shop, right? But then does that make hand assembled cars like exotic Italians "built not bought"?
Is it the changes to the car that make it "built"? If so, then a factory restoration was not "built".
Useless banter but fun to think about.... Thoughts?
Old 08-23-2021, 05:21 PM
oregonphil oregonphil is offline
POW. That just made my head explode.
I think your conclusion is correct:
"But then again, maybe a vehicle that is generally modified by the owner (or their shop) should fit in here somewhere?"
Thou I would never put that sticker on my car just because it did not come from the factory that way. At least it did not say "hand built not bought".
OregonPhil
77 SJ 401
72 Commando 304
07 Toyota Sienna
76 HD FLH
Old 08-23-2021, 08:27 PM
JPSwapMohn's Avatar
JPSwapMohn JPSwapMohn is offline
I don't think there is a line that has to be crossed, but to my eye, Built would be significant modification done mostly by the owner.
Example: My YJ mutt is built. The only things still original to it are the frame (straightened twice), most of the body, and the bottom end of the engine. I put in wagoneer D44's w/ CrMo shafts and ARB lockers, spring-over suspension on 2.5" OME springs, Bilstein reservoir shocks. I built the transfer case from D300 parts, aftermarket parts, and a STaKs case. The transmission is built AX-15 (bought), we made the body armor and I put a CJ7 hood and grill on it by modifying the mounts, etc. The seats are PT Cruiser, the center console is an ammo can I cut and welded. I did buy the bumpers instead of making them. A buddy and I designed and welded up the rear axle truss and anti-wrap bar/mount. The rear shocks were inboarded at top to give more articulation. It has modified TJ larger exhaust and I rebuilt the top end with some minor head work that was within my skill level. It is bounced off rocks, trees, whatever. I break it and rebuild/improve what I break.
I consider my mutt to be built... but I wouldn't put that sticker on it. 8^)
One day I will wake up and realize that my jeep is complete...one day, I just know it.
88Wag, LT1/4L60E/NP242, F150 fuel cell, discs, Aussie rear, LDS front, 4.10s
http://imgbox.com/g/rNuIasKYrS
95YJ, STaK 300, D44's, SOA, ARB's, 4.56s, Bilsteins, 35" KM2's
50 CJ3A
77 J-10, 360/T-18/D20, SOLD
Old 08-23-2021, 09:31 PM
FleetFox's Avatar
FleetFox FleetFox is offline
My honest opinion is if you put a sticker like that on it, you feel like you something to prove. Or you're a bottomless pit of need and want for attention. And there's just nothing anyone is going to say to you about your rig that's gonna fill that hole. I take my stuff to cruise ins only occasionally. I park it and walk around to see some of the really neat engineering and stuff other people have put into their projects. Just me.
Fleet Fox
Old 08-24-2021, 12:02 PM
Brynjminjones's Avatar
I've never liked the term "Built Not Bought", it always seems like gatekeeping to me and I've never understood why it matters.
Loads of people here in the UK have those stickers, yet have bought a brand new car and simply spent loads at the shop getting it modified.
My XJ on the other hand is completely stock, yet I've had it for the last 9 years and I guarantee I've put more work into it than lots of people with modded cars have!
I don't think there's really a way of defining how much work somebody has put into a car.
Some people do it all themselves, others work hard to afford to pay a shop!
I'm won't hold either against somebody!
1991 Grand Wagoneer - Hunter Green. All stock. Rebuilt 360 with Melling MTA-1 cam.
1998 Cherokee (XJ) 4.0
1997 Grand Cherokee (ZJ) 4.0
1974 Ford F100 390
Old 08-24-2021, 09:01 PM
SJTD SJTD is offline
Does it have to be running to be considered "built"?
Sic friatur crustulum
Old 08-25-2021, 07:06 AM
backroadin''s Avatar
Originally Posted by FleetFox
I walk around to see some of the really neat engineering and stuff other people have put into their projects. Just me.
Me too - this is what I think of when I hear that saying.
We all got different levels of skill, time, and space to do stuff - and what we each consider "building our rig" isn't going to be the same as the next guy. But I do think you gotta do a good percentage of the work or installment yourself to be considered "built."
BUT - if you put that sticker on your ride, you'd better have done more than just slap on LED's , stickers, and rims and tires for me to have respect for it! Like the old saying goes, "If it don't make ya dirty, it ain't yours."
(Lease rigs need not apply....... )
Old 08-25-2021, 10:07 PM
JPSwapMohn's Avatar
If you haven't bleed on it, is it really yours?
50 CJ3A
Old 08-26-2021, 08:12 AM
We're in luck - looks like you can build a wagoneer at jeep.com.
1984 GW
360
Comp 260H
Harland Sharp Roller Rockers
Wiseco -21cc Forged Pistons
Performer Intake
Holley SA 670
MSD 8523
Dakota Digital custom cluster
Serehill headlamp harness
NWMP aux tank
1987 GW deceased
...but the parts live on
Old 08-26-2021, 05:18 PM
Tripwire's Avatar
Tripwire Tripwire is offline
Wink
When your rig ( especially baby jeeps ) looks like a rich kid got ahold of mommies credit card and a few aftermarket accessory magazines and looks ridiculous
Abort? Retry? Ignore? >
Old 08-27-2021, 07:44 AM
LOL, that sure blurs the lines.
Thinking about it, my 88 must be both. Since I 'built' it myself I still 'bought' many of the parts with which to build it.
I suppose it's what the 'built not bought' wording implies.
Can I get rich off "Built in My Garage" decals?
How about "Built-ish"?
--Rob--
My build thread:
My Howell TBI Install How-To:
Old 08-27-2021, 01:36 PM
That I like, it would apply to 97% of our rigs.
OregonPhil
77 SJ 401
72 Commando 304
07 Toyota Sienna
76 HD FLH
Old 08-28-2021, 11:02 PM
wagoneer84's Avatar
wagoneer84 wagoneer84 is offline
Personally i would have to agree with this, I have had my wagoneer for 15 years and i am the only one who has worked on it. Including changing the gearing, installing lockers, to building my own cage and bumpers. We can't forget all the upgrades that are mentioned in these forums like the ammeter delete or adding relays for windows or lights to rewiring for a higher amp altinator.
84 wagoneer 360/727/np229
amc 20 rear detroit ez locker 4:56
dana 44 front aussie locker 4:56
