Old 08-13-2016, 02:35 PM
KdkGrizz's Avatar
KdkGrizz KdkGrizz is offline
Charcoal Canister MIA after engine rebuild
Hey everyone, Well the engine rebuild went well, and after the install, and testing etc, we were putting the finishing touches on the engine compartment. I went through every bin, and I am unable to locate the charcoal canister or it's bracket. I fear it may have ended up in one of the bins that were donated to the local boneyard. So other than venting of the fuel tank, how bad off am I?
Oh yeah, the motor is not stock anymore. No emissions, only a PCV. New manifold, carb, MSD ignition, etc etc. Not stock but not outrageous.
I am not sure how critical the canister is, so I thought I would reach out to people smarter than I.
Be good, and keep it safe all.
~Kodi....
Kodi
82 WAGONEER It's a project
360ci 727 and NP208
The early bird may get the worm, but the second mouse always gets the cheese...
Old 08-13-2016, 04:09 PM
I haven't ran one since 2007. Not a big deal. There may be a slight fuel smell if you park the vehicle in the garage but I hardly notice.
-Jonny B.
AMC 401 - Pro-Flo 4 EFI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 08-13-2016, 08:20 PM
asudchiman's Avatar
asudchiman asudchiman is offline
Will run fine, but X2 about fuel smell. If I park in the garage it is fairly strong. So much so that I am going to retrofit a charcoal canister.
Current Jeep Fleet:
1993 Wrangler Sahara (YJ) Stock, 52k
1991 Grand Wagoneer - [Black] 4" Lift, 32's, 92k
1991 Grand Wagoneer - [Hunter Green] Stock, 60k
1991 Grand Wagoneer - [Hunter Green] Restored (for sale)
Four Wheel Trends
Old 08-14-2016, 05:11 AM
KdkGrizz's Avatar
So in looking at the OEM vacuum diagram, I see that canister is looking for a vacuum line into the intake. I assume the idea here is to pull those vapors when driving, and burn them. Think I might have an available 1/8 NPT on my intake that I can use. The line to fuel tank splits into 2 lines, I believe the other vents the trans as well. But I could be wrong.
Kodi
360ci 727 and NP208
Old 08-14-2016, 06:07 AM
The trans vents to atmosphere. The fuel tank and carb bowl vents to the canister. Under engine load the canister vents to the engine and the trapped vapors are burned. Since you have an aftermarket carb just plug the port on the intake and leave the vent line from the fuel tank open to vent. Maybe install one of those vent caps on it like the front and rear diffs use
-Jonny B.
360 Engine Rebuild Kits AMC4ME General FSJ Tech 10 09-15-2014 08:24 AM
Engine rebuild help in Eastern VA Jondeaux South East 0 07-02-2013 11:45 AM
Engine Rebuild? Or...crate engine? AnnieL General FSJ Tech 11 04-19-2013 10:18 PM
Looking for tips on engine rebuild bgscott General FSJ Discussion 10 07-20-2012 05:20 PM
charcoal canister lines??? 3 on ps. side 1BDWAGN General FSJ Tech 10 03-03-2005 12:05 PM
