05-16-2022, 03:51 PM
This thread needs to be a sticky.....please
Washed out fuel tank of 18 yrs since last driven.
Put some gas in existing carb and tried to start it. No start.
Traced connections for no spark, and finding MSD-6A not getting power from IGN wire.
Cleaned up solenoid starter connections.
More detailed pics taken of interior and specific body damage (minimal).
1984 Grand Wagoneer, 401 ci (.030 over), A727 auto, Selec-trac NP229, AMC 20 REAR - D44 FRONT (6 LUG) WT 3.31, 4 in arch spring lift (not a woody - think it was ordered new without, 1984 the only year it was an option)
Rather be driving, than waiting for modifications!
05-19-2022, 09:57 PM
I drove it!!!
Any weekend I can do that and not open the tool box is a good weekend!
"When this baby reaches 88 miles per hour, you're gonna to see some serious sh  t!"
05-20-2022, 09:40 AM
I drove mine too!
My '91 hadn't been used much for a while and was sitting in the garage.
I had a long trip planned two weeks ago, and a couple days before I realized the other cars were all out of action for various reasons.
I fired up the Wagoneer, pulled it out of the garage and put 700 hard miles on it without it batting an eye.
Drove it all of the following week, then another big trip this weekend just gone.
In total, I put around 1500 miles on it (getting compliments the whole way) over that 10 day period and it took it like a champ.
I even used it as my mobile office, much to the amusement of everybody at my work.
I always loved this Jeep, but never expected it to be such a solidly reliable workhorse!
Mobile Office by Brynjaminjones, on Flickr
Plymouth Road Trip by Brynjaminjones, on Flickr
Night Waggy by Brynjaminjones, on Flickr
1991 Grand Wagoneer - Hunter Green. All stock. Rebuilt 360, .030" over with Melling MTA-1 cam.
1998 Cherokee (XJ) 4.0
1997 Grand Cherokee (ZJ) 4.0
1974 Ford F100 390
05-20-2022, 11:59 AM
That is so nice to hear it worked flawlessly for you
I will be chasing electric issue this weekend.
Brought home a '84 Grand Wagoneer 4 weeks back, already pulled and cleaned the fuel tank so waiting for parts to put back on, but MSD-6A does not test out and no power from IGN wire. Hence, no spark to fire it up.
05-21-2022, 07:41 AM
Brynjminjones, I love the "shoes kicked off" in the first pic!!
(Or are those just spares...  )
05-21-2022, 05:01 PM
Chasing wires......
Found some questionable wiring (duct taped connections, MSD soldered into electric choke circuit, voltage dropping out of IGN on feed) but closer now than this morning.
Getting out of the heat for a bit, then back at it
05-22-2022, 07:54 AM
Originally Posted by devildog80
Chasing wires......
Fond some questionable wiring (duct taped connections, MSD soldered into electric choke circuit, voltage dropping out of IGN on feed) but closer now than this morning.
I think the duct tape is factory.
05-22-2022, 09:18 AM
Yep, AMC used the best...
05-22-2022, 09:22 AM
Chasing wires......
Check the ignition switch under dash on steering column. I have had the metal tabs that hold them together relax and cause problems.
05-22-2022, 03:13 PM
Interesting.....as the truck has sat for, close as we can figure, 18 yrs.
Hit it again last night for 4 hrs, added to the morning 6 hrs, then again this morning.
Having trouble getting full 12+ volts to the passenger side, which seems the most we can get is just 9+ a little, and no voltage to the coil.
We did determine that is next step, to do exactly as you just advised, so that is my homework for the week.
Thanks, and please throw any other tips this way, as I could use them
Start switch is so far up on the column, I need to drop the under dash A/C unit down, so I can access it to clean/tighten connections. Hope this clears up voltage drop in the engine bay.
Took out MSD system, went back to OEM with ECM/coil, and still the same readings.
20220522_080245 by Scott Weckerly, on Flickr
20220522_080257 by Scott Weckerly, on Flickr
05-22-2022, 06:34 PM
The drivers side air duct comes off separate from the rest of the unit. Sometimes loosening the 2 bolts that hold column bracket to dash helps. While under the dash look up at the back of the instrument panel, your 84 will have an Amp meter. Check to see if the 2 large main feed wires are on the SAME lug. If they are on separate lugs then the Amp meter might be part of the problem. There have been stories about them burning Jeeps down.
We should be doing this on your build thread...
05-23-2022, 10:19 AM
Yep, I posted on the build thread too.
Just threw it on here, as it is nice to see all the threads moving along
Thanks.....see you over on build thread
05-23-2022, 12:21 PM
Pulled all the window parts and electric wiring out of two used but without rust and completely straight front doors to have them prepped for blasting and painting.
The original doors of the 73' j4000 are to far gone on the bottom side.
The drivers side was never a straight door when I started thirteen years ago and had removed and shaved the lock from passengers side door.
But it's was not always very practical
So now the truck is totally disassembled for a second overhaul it's time to replace what i don't like anymore or is rusted out to much.
Also going to put electric windows on the truck because it's way easier to pull the passenger window down from the driver's seat without stopping.
73' Jeep J4000 (named Heep or Desert Dragon) amc 360 V8 converted to LPG with T15/D20 (was my daily work truck for thirteen years and is getting major overhaul at the moment!)
80' Jeep cj5 350 V8 Chevy/sm420/D300 project
70/71 Jeep J4000 parts truck with Buick 350
Former vehicles:
05-24-2022, 03:37 AM
I'd driven for about 6 hours, then worked from the car for another 3-4 - I felt the need to kick my feet up!
1974 Ford F100 390
05-24-2022, 10:41 AM
I day dreamed about the two tone paint that I will get on it ...someday. ....and picking it up in a few months (I am currently FSJless).
( Cherokee Build Thread)
00 Baby Cherokee
05-30-2022, 06:37 PM
Well, this extended weekend I did a lot of driving it. Then today I got it washed (and vacuumed!). I also got the tailgate latches adjusted properly.
Next weekend I'm hoping to do an oil change (and install Helicoils in the timing cover, to make the oil pump seal up better), and hopefully install the new bushings I have for the front suspension. Then it should drip less AND stop wandering when I hit a big(ish) bump...getting pretty fancy here
05-30-2022, 06:41 PM
I put a thousand miles on mine too......in my dreams
05-30-2022, 07:12 PM
I didn't go 1,000, just like 200 or so
Boy, I don't know, odometer is showing almost 10,000 miles...again. (Ok, fine, it rolled over this fall, so it's something hundred ten thousand). I'll just pretend it's brand new though
05-30-2022, 07:39 PM
Yep.....chomping at the bit on mine, but work - or lack thereof - keeps getting in the way.
I keep living the dream......and making progress a little at a time
Still working to get it running, but took the '84 grill and headlights off, as I want to convert to the old Rhino Grill look.
Here is an '81 in same color as my '84. Looks almost like a Rolls Royce
a9e4331d73bfc6223d351531f1a63e91 by Scott Weckerly, on Flickr
05-31-2022, 01:42 AM
Filled all the not needed holes in the two new for my Jeep doors and tinned them smooth.
It's time consuming but I like the end result!
Former vehicles:
Thread Tools |
Display Modes |
