Old 05-16-2022, 09:03 PM
jeeprs's Avatar
jeeprs jeeprs is offline
Motor oil
Hey guys I just got a 88 Grand Wagoneer and was wondering what oil you use or recommend. Conventional/ synthetic? It's got 122k miles on it.Thanks
70 J2000
77 Cherokee Chief
79 Cherokee
87 Wrangler
88 Grand Wagoneer
Old 05-17-2022, 04:29 AM
Any oil you can find will work fine, save some money and go regular oil.
Old 05-17-2022, 11:11 AM
devildog80's Avatar
devildog80 devildog80 is online now
x2 on the dead dinosaurs, and in AL I would use 10-40, as you probably never drive it enough to get the benefit from the synthetic.
1984 Grand Wagoneer, 401 ci (.030 over), A727 auto, Selec-trac NP229, AMC 20 REAR - D44 FRONT (6 LUG) WT 3.31, 4 in arch spring lift (not a woody - think it was ordered new without, 1984 the only year it was an option)
Rather be driving, than waiting for modifications!
Old 05-17-2022, 08:24 PM
backroadin''s Avatar
I run regular rotella 15-40, but the motor is rebuilt and has aftermarket cam, so I do it for the extra zinc. For yours, what willey-mo said.
You can run the high mileage oil - it's usually no more expensive.
And Walmart brand oil is actually not bad..... just sayin
Old 05-17-2022, 09:29 PM
'89_Wagon '89_Wagon is offline
I've thrown rotella, wally world oil, and Yamalube at my high mileage motor. No difference with any of them. I needed a little bit of the Yamalube for another machine and didn't feel like going out to the store.... so in the Jeep it went!
'89 Grand Wagoneer
AW4 Swap
Old 05-18-2022, 08:37 PM
jeeprs's Avatar
Thanks for the info guys
70 J2000
77 Cherokee Chief
79 Cherokee
87 Wrangler
88 Grand Wagoneer
Old 05-19-2022, 06:36 AM
Crankyolman's Avatar
After my cam went bad leading to an engine rebuild I did a ton of research on oil. Oil companies continue to change their formulas and continue to remove the things needed by non roller cams. This is true of diesel oils too.
Now, granted my engine is older (1972) but my understanding is they never changed the cam to roller so it still needs the zinc.
After all that research I started using Lucas Hot Rod oil because it has the highest zinc of any of them. You could run 50% HRO and 50% regular oil and still have more than most including rotella. The only real problem is this may cause eventual clogging of the cataly converter but personally I'd rather change that than the engine.
'72 J4500
Old 05-19-2022, 03:49 PM
sierrablue's Avatar
sierrablue sierrablue is offline
x2 on the 10W-40. More zinc = more engine life, pretty much whenever you don't have a roller cam and/or lifters. The reason I don't go synthetic is that it leaks; no point in flushing money into a fluid that goes through a quart every week and a half or so...
Current Rig:
'71 Wagoneer (DD)
B350/TH400/D20
open knuckle D44 front (disc brakes)
6-lug conversion rear
http://www.ifsja.org/forums/vb/showt...79#post1734879
Previous Rig:
Tan '88 Grand Wagoneer
.030 over 401, TBI, headers
3" exhaust
31x10.5s
2" rear lift blocks
custom headliner
http://www.ifsja.org/forums/vb/showt...77#post1734777
"The engineering side of me says that it's more than strong enough. The redneck side of me says that it's going to fall apart and I need to beef it up."--somebody I know
Old 05-19-2022, 03:53 PM
Cliff's Avatar
Cliff Cliff is offline
I use Brad Penn oil because of the zinc. I had used it in a drag racing AMC Spirit with a 401, and it made sense to use it in the Jeep too.
Cliff Danley
1977 Cherokee S
Old 05-23-2022, 02:17 PM
The bigger comment: DO NOT USE CRAPPY OIL FILTERS!!! I used a Fram on my 401 break-in and my engine sucked the filter element up like a straw. I had always run cheapie Fram and generic oil filters and thought people were being dramatic when they hated on cheapie filters. Never again.
Run WIX or Baldwin. I read all over the AMCForum and those guys all swear by the Baldwin B8. I am not sure what year needs a metric filter so research that (B8 is NOT metric and 88 MIGHT be the first year of metric filters...).
00 Baby Cherokee
Old 05-24-2022, 03:51 AM
Brynjminjones's Avatar
I use 10w40 here too. Just regular Valvoline MaxLife for me.
Mine has a rebuilt motor with about 10,000 miles on it. I used 20w50 for a while, but it seemed too thick when cold and I could hear that oil wasn't circulating as quickly as I'd like.
With 10w40 it builds oil pressure nice and quickly on startup, but keeps high enough pressure at hot idle after a high speed run.
I also changed the oil filter adapter to take the Mopar 090 filter, as used by Jeeps with the 4.0.
I've always found it to be a good filter, plus I like only having one type of filter for all our Jeeps!
1991 Grand Wagoneer - Hunter Green. All stock. Rebuilt 360, .030" over with Melling MTA-1 cam.
1998 Cherokee (XJ) 4.0
1997 Grand Cherokee (ZJ) 4.0
1974 Ford F100 390
Old 06-02-2022, 03:14 PM
nograin's Avatar
nograin nograin is offline
Depends how worn it is and how hot it runs.
10W-30 should be fine but if you see the oil runs hot, or that the engine seems to be eating oil, then try 10W-40. My last 360 was pretty worn and was getting the previous generation of Rotella 5W-40 synthetic T6. The lower W grade is a little easier on the engine when cold. If you aren't in a cold climate or not doing a lot of short runs, then its not so important.
if you want to get into the ZDDP game, look for an oil with at least 600 and no more than 1400 ppm. Valve spring pressures on a stock 360 cam are not anywhere in the range where one should be sweating this.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
