Old 04-27-2022, 09:52 AM
Anyone follow XJ forums? Recomendations?
I have some tasking for my XJ and need some help. I see about 5 different XJ forums out there. Anyone on any of them? Like them? Hate them?
00 Baby Cherokee
Old 04-27-2022, 12:08 PM
Heep-J4000's Avatar
Aren't there people on this forum that have a xj series jeep?
Like some of us also have a cj jeep.
So I think you easily can ask your question here!
73' Jeep J4000 (named Heep or Desert Dragon) amc 360 V8 converted to LPG with T15/D20 (was my daily work truck for thirteen years and is getting major overhaul at the moment!)
80' Jeep cj5 350 V8 Chevy/sm420/D300 project
70/71 Jeep J4000 parts truck with Buick 350
Former vehicles:
Old 04-27-2022, 01:05 PM
asphaltrockdweller's Avatar
Cherokeeforum.com but stupidity rules the day there.
LOL So wouldn't you know I am over there some of the time.
Then NAXJA
NAXJA is a club, that just happens to have a forum too!
Info is pretty spot-on over there.
Old 04-27-2022, 02:12 PM
DBX11's Avatar
DBX11 DBX11 is offline
Hey I have an xj what are your questions?
Old 04-27-2022, 03:35 PM
goldhammer's Avatar
I can't get into naxja anymore, and no replies to get it ironed out.
Have an '88, ask away either here or PM
Art
ASE Master Collision Tech
Old 04-27-2022, 04:58 PM
Thanks everyone! Good info! We were going to sell it but now we have other plans for it.
Here is the first question:
I am getting ready to pull the AW4 out to rebuild it and convert to 4WD. I have ordered the adapter and output shaft already. I plan to keep this truck almost completely stock because we are just going to use it to tow behind our RV. I plan to run an NP242 and open diffs front/rear. The trans works OK right now but shudders into gear sometimes. I also plan to add a Transgo shift kit and trans temp gauge while I am in there. External cooler will come later. I do not plan to replace the torque converter. My goal is a stupid reliable, long lasting rig that we can take on dirt roads, snow'byng sometimes, etc.
I have done a Ford AOD and a TH400. I plan to replace all clutches and steels (I don't ever want to go into this trans again). I do have the ATSG for it.
Anywho, Looking around I see quite a few trans rebuild kits. Any advice for kits to avoid? Any you recommend? Any other advice?
I posted this over on jeepforum.com, too (because I already had an account over there). I applied for an account on NAXJA but have not been approved yet.
00 Baby Cherokee
Old 04-30-2022, 12:07 PM
Kaiserjeeps's Avatar
360 AMC
I am looking too Rang. I have a friends 98 with the typical power window and lock no workie issues. It is currently sitting on my trailer behind the Dodgemahal right outside. I will be making the 4 hour trip home on Monday. They are neat little rigs. I suspect broken wires in the door harness where it flexes all the time. Please post up your findings on forums..
Am I done yet?
Holy Moly, I am done.....
1969 1414X Wag,
71 J4000 Rang-A-Stangs next project!!
1970 J truck with the 71
1970 Wagoneer Not Sadie
1983 FJ60 wagon
CJ-5's
Old 05-05-2022, 05:17 PM
I was able to find the 2000 field Service Manual online and have downloaded it. I am on jeepforum but its even quieter there than it is here. I am still waiting for my account to be activated on NAXJA.
00 Baby Cherokee
Old 05-05-2022, 11:01 PM
kaiserjeeps:
Replace the passenger front door, window/door lock switch. It contains the lock/unlock relays. Buy one from Switch Doctor on Amazon for approx $25.
Dave
Old 05-06-2022, 04:37 PM
360 AMC
I had bought a new drivers door master switch and passenger window motor. Still has all the issues. I will have a look there. I towed the XJ to my home and it is sitting outside waiting for me. I had been reading the wiring breaks in the harness that transitions from the door to the body. To much flexing over time. I did find a CD with the factory manuals on Rock Auto. It is on the way. I want wire colors and schematics. But I will have a look at your suggestion. That is all that is wrong with this rig now. Thanks Dave!!
Am I done yet?
1969 1414X Wag,
1983 FJ60 wagon
CJ-5's
Old 05-07-2022, 09:21 PM
I have had the wires at the door hinges break, usually on the driver's door as that is the one that is opened and closed the most for most rigs. The speaker wires often break on both front doors, then sometimes the door lock wires. Take off the inner door panel and the foot panel inside the vehicle. Then unplug the rubber accordion tube from the door jamb. I believe that you can then slide the rubber into the door or perhaps unplug it from the door. Unplug the harness behind the foot panel (there are about 3 connectors). You should be able to get enough slack to examine the wire harness in the space between the door and the jamb. Undo the tape wrap and you should be able to find the damaged wires by visual inspection or by feeling them. They break in the center, half way between the two metal surfaces. Sometimes a wire will have half of the strands broken. If it bends easier than the others, and it is the same gauge, then it may have broken strands. Strip the insulation to check.
When repairing, run a new piece of fine multi-strand wire of the same or slightly larger gauge. Cut out the damaged wire section and solder the new piece inside the door and inside the car. That way, the soldered sections (which are stiff) will not be in the "flex zone". Insulate the soldered joints, re-wrap the wire bundle and put the rest back together.
Goog Luck.
Dave
Old 05-08-2022, 03:26 PM
360 AMC
Most excellent info and help Dave. I plan on a dedicated day on the XJ this next week. Many thanks!
Am I done yet?
1969 1414X Wag,
1983 FJ60 wagon
CJ-5's
Old 05-24-2022, 03:43 AM
Brynjminjones's Avatar
Did you get this done in the end?
I also have a 1998 XJ and have had to deal with this exact issue. I did as described above:-
-Remove kick panel and unplug everything
-Remove door panel and unplug all wires
-Remove rubber accordion in door jamb
-Remove entire wiring harness - it pulls easily enough through from the hinge area
Once it was out I found loads of damaged wires. I spliced in whole new sections (about 3 inches long) using these self-soldering heat-shrink tubes:
https://www.youtube.com/watch?v=7Wh5gM8GM70
This was a couple of years ago, and everything has been working 100% perfectly since!
1991 Grand Wagoneer - Hunter Green. All stock. Rebuilt 360, .030" over with Melling MTA-1 cam.
1998 Cherokee (XJ) 4.0
1997 Grand Cherokee (ZJ) 4.0
1974 Ford F100 390
Look what's about to follow me home... lunchbox1671 General FSJ Discussion 18 12-18-2012 09:17 PM
Shipping recomendations ChiefWooHaw General FSJ Discussion 8 07-18-2007 06:44 AM
cherry picker recomendations Brad W. General FSJ Discussion 33 07-07-2007 07:37 PM
Suspension recomendations farinspace General FSJ Discussion 2 07-05-2007 12:42 PM
jeep forums jeeprunner81 General FSJ Tech 3 05-02-2006 12:07 PM
