  #41
Old 11-13-2017, 08:09 PM
MtnYJ MtnYJ is offline
Originally Posted by Rod2
I want your 5th over gear to put in my T-18; of course I want you to do the engineering and the mechanicals.
Here ya go Rod, all the info for adding that 5th gear! ;-)
http://www.novak-adapt.com/knowledge.../manual/nv4500
Tim & Sarah
'84 CJ-7, AMC 401
'76 J20, T-18, Dana 20, no floors
'91 GW, AMC 360, AX-15, NP 208, 178K Mi
Rear bumper w/swing-out tire carrier
'93 YJ, 4.0L, 5-SP, flipped Dana 300, Dana 44s
'14 Ram 3500 4x4 CTD
Carolina Full Size Jeep Club President http://www.cfsjc.com
Old 11-13-2017, 11:55 PM
j10jim's Avatar
j10jim j10jim is offline
Originally Posted by MtnYJ
Hi there fellas, it's been a while since I visited here! As far as the shifter goes, if I remember correctly I used the shifter out of the same J truck that donated the NP-208. I don't recall it even being as complex as acct21's pictures - I'm pretty sure I just used the pivot point that bolts to the floor. That pivot holds a simple t-case shifter rod, then the bottom end is connected to the modified 727 linkage pieces. I know that's still not a ton of detail, but it is pretty simple linkage, and works extremely well. There's no binding at all, I can pretty much shift into/out of 4WD with one finger.
We drove the Waggy nearly everyday until Fall 2015, when we lost a head gasket. The transmission swap never gave us a minute worth of trouble. We parked it and decided to build the wife a CJ. The Waggy is the next project, and will be getting an LS, NV-4500, and Dana 300.
Thank you for the updated info. I will look for one. I used to have one, just need to see if I can find it.
1980 J-10<br />Rusty\'s 4 inch lift<br />2 inch body lift,<br />35 in Xterrains on J20 axles<br />4:30 gears<br />Detroits<br />In-Cab cage thru the dash
Old 04-22-2022, 06:59 AM
GrandWaggy89 GrandWaggy89 is offline
Where did the photos go? d
Where did the photos go? I was using this a my bible for my build and I'm stuck how I should set up the linkage for 4Lo/Hi on my NP228.
If there's anyway to recover the photos or if anyone has some tips on how to best connect the linkage for 4Lo/Hi that would be a huge help to me!
I'd like to be able to use the original shift lever on my 89' that's on the floor near the driver's seat.
Hope someone sees this and can help!
Old 05-20-2022, 11:16 AM
PlumCrazyChris PlumCrazyChris is offline
MtnYJ, is there any way to get the photos back on this awesome thread?
PlumCrazyChris
Round Rock, TX
1979 Cherokee Chief 360/T18
1990 Grand Wagoneer - sold
1983 Cherokee Laredo Limited - sold, and want it back!
1979 Cherokee Chief - sold
1976 Cherokee Chief - sold
Old 05-23-2022, 11:34 AM
MtnYJ's last logon was 01-06-2019.
00 Baby Cherokee
weirdest auto transmission issue on 727 sportsidedan General FSJ Tech 7 10-11-2010 12:42 AM
'91 GW overdrive automatic transmission swap Greg Clark General FSJ Tech 4 07-22-2005 08:20 AM
727 Transmission Noise Kevin718 General FSJ Tech 4 01-25-2004 03:10 PM
AMC/Jeep Manual Transmission Info James 007 General FSJ Tech 0 09-02-2002 07:40 AM
