Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > For Sale: Parts and Pieces (To keep our rigs running)
Old 05-20-2022, 04:40 PM
devildog80's Avatar
devildog80 devildog80 is offline
MISC to assist FSJ remote work
Bought this new August 2020, put a little gas in and ran it until empty to test all plugs and make sure it all worked, about 5 hrs, then drained the carb and fuel line dry.
Bought for camping but too big to lug around, and thinking I would have used it for plugging in my house, but have not used it for either.
Asking $360 cash please, it is essentially new, as I have original receipt and the box it came in.
This has 240V capabilities (see full details below) so could plug in a welder, dryer, home oven (for powder coating so you leave momma's alone in the kitchen), or your whole house.
PM me or text GENERATOR @ six-zero-2-nine-0-9-two-0-five-9 and I will respond back
4375 Watt Gen 63962_W2 by Scott Weckerly, on Flickr
The PREDATOR
4375 Watt Portable Generator is ideal for emergencies, job-sites, food trucks, and outdoor recreation. Powered by a reliable PREDATOR gas engine, this generator has GFCI outlets, a larger fuel tank, and delivers longer runtime, making it an unbeatable value. 4375 starting watts and 3500 running watts make this unit capable of powering several home essentials during an outage or providing power on the go. Our new, larger gas tank means you can enjoy runtime up to 16 hours @ 50% load.
Runtime up to 16 hours @ 50% load
Heavy duty 1 in. steel roll cage
Low oil indicator / low oil shutdown
212cc, 6.5 HP air-cooled OHV gas engine
UL listed circuit breakers
(4) 120v GFCI outlets, 3 prong, (1) 120/240v twist lock outlet, 4 prong, (1) 12v DC outlet
'81 CJ5 Base, 258 I6, MC2100, T176 4 spd, 300 TC, D30 Front NT, 3.31, 2-Piece AMC 20 rear NT, 3.31, 4" high arc spring lift
'84 Grand Wagoneer, 401 V8 (.030 over), MC2150 HA Comp, 727 auto, Selec-trac NP229, AMC 20 REAR - D44 FRONT - WT 3.31, 4" high arc spring lift
Rather be driving, than waiting to be modified
Old 07-23-2022, 12:29 PM
devildog80's Avatar
Will take $300
Nice Waggy!!! OR Crispyboy skips out of work early... HOOT General FSJ Discussion 5 06-24-2010 09:06 PM
Hydro Assist problem... BRUTUS Off-Road FSJ Tech 21 09-11-2008 02:05 AM
remote entry with factory sunroof option? wentawagon General FSJ Tech 3 05-17-2006 11:28 PM
Remote Locks, Remote Start, Remote Tailgate Window and Alarm INSTALLED! DaddyO General FSJ Tech 10 01-03-2005 01:17 PM
