Old 11-27-2008, 07:49 PM
BURT's Avatar
BURT BURT is offline
double cardan joint
is the center of the double carden joint replacable ? if so how do you get it out?
burt
Old 11-27-2008, 09:15 PM
Subic Jeep's Avatar
Subic Jeep Subic Jeep is offline
http://quad4x4.com/Jeep%20Driveline.htm
http://www.pirate4x4.com/tech/billav...aft/index.html
Old 11-28-2008, 09:04 AM
BURT's Avatar
found the u joints & center piviot ball at napa, what I am seeing the pin on the shaft is not sevicable , just the ball set up . How do you get it out?
burt
Old 11-28-2008, 09:31 AM
If you have access to a lathe, you can build up the bad spots with a welder and turn them down to the correct size. I've seen it before.
46 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 11-28-2008, 10:14 AM
BURT's Avatar
my pin is ok. I just need to change the ball. How does it come out
burt
Old 11-29-2008, 07:29 AM
I have a press, but have also used a large C-clamp and a couple of sockets. When you remove the u-joint that attaches to the t-case, it'll perty much just fall out. It's a PITA, and a spare set of hands is helpful. Then remove the "H" piece and then pull the other joint and reassemble in reverse.
Just have to take your time and make sure none of the needle bearings fall during assembly.
Hope this helps.
46 cj2a
51 Willys p/u
'74 CJ5
'75 J-20 Wrecker
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
