Old 12-19-2006, 10:47 PM
Locked and Loaded's Avatar
Locked and Loaded Locked and Loaded is offline
Model 20 Limited Slip
I noticed that the model 20 rear end on my j10 has CC stamped on it. According to the factory manual that means 3.31 gears and limited slip. I never thought it had limited slip. So it must be worn out or it doesn't have it any more. I pulled the cover off. Should I be able to see the fricton plates in plain view? Do any of you have pictures of what it looks like? The exploded view in the manual is deceiving. Also where can I get a step by step procedure to rebuild it?
Drink more water.
"Nothin' ain't worth nothin'.
But it's free"
Kris Kristofferson 1970
1981 J10, 258, T176, NP208
Old 12-19-2006, 11:00 PM
Crazy_Jeepman's Avatar
Sloppy Shifter
Won't be in plain view, but usually you can see them if you look carefully. They would be behind the side gears. Here is a diagram from a baby Jeep 20 #24 is what you are looking for in your diff
http://www.jeepdoc.com/catalog/partspix/AMC20TLoc.jpg
Old 12-20-2006, 10:13 PM
Have any of you rebuilt a trac lock?
Drink more water.
But it's free"
Old 12-21-2006, 09:16 AM
J10Mike's Avatar
J10Mike J10Mike is offline
Delightfully Incompetent
I didn't rebuild one. But, I did pull one apart for the heck of it to get a close up understanding of a clutch plate based LSD. Not bad at all. I think the one of the most important things would be to make sure the new clutch plates go back in in the right order. Also, I would replace the cross shaft as well since they seem to show some wear.
www.j10mike.com
Old 12-21-2006, 10:24 AM
There's some extra help about rebuilding the Trac-loc on the Randy's R&P site: http://www.ringpinion.com/ContentFra..._Made_Easy.inc
Old 12-24-2006, 10:35 PM
Since I can't see the clucth plates and I don't want to tear it apart to see if it is trac loc I guess I'll put the cover back on an assume it's an open diff. I was just hoping it was visable. Someone told me if I raise the rear end and spin one tire if the other tire goes in the opposite direction it's open. If it goes in the same direction it's limited slip. Is this true? Mine spins opposite. I guess it's open. Wonder why CC is stamped on it?
Drink more water.
But it's free"
Old 12-25-2006, 09:07 AM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
That works with a full locker, like a Detroit. Not sure if that works with limited slip...
Old 12-25-2006, 09:14 AM
Sloppy Shifter
Yes both wheels will spin the same way IF the clutch packs are in good condition, once they wear out, it will act just like an open diff. You can tell with the cover off, if you were to look carefully you would be able to see clutch packs behind the side gears, look like washers.
Old 12-25-2006, 12:15 PM
Thanks for the info. Does anyone have any pictures of the clutch plates with the cover off?
Drink more water.
But it's free"
Old 12-25-2006, 12:25 PM
Sloppy Shifter
Thats what you are looking for behind the side gears
This will be similar to what you need to see.
If you look behind that side gear, you see the clutch packs in there. These are not AMC 20 carriers but are going to be similar to what you need to see
Old 12-26-2006, 10:38 PM
Thanks. That is what I was looking for. Looks like I have trac Loc. I'm gonna start tearing into it tomorrow. If any one has done this, are there any warnings?
Drink more water.
But it's free"
