Old 11-08-2006, 12:37 AM
DanHS's Avatar
DanHS DanHS is offline
Quick, what's the dimensions of the o-ring on the trans shifter?
Ok, I need to know the dimensions of the o-ring on the shifter linkage seal on my 727 so I can try to replace it with one from the hardware store rather than attempt to get one from the parts place or annoy the transmission place. Anybody know? I tried taking the one out of my old 727, but it was way to stuck in to remove with a regular seal pick. I'll try measuring it where it is, some known dimensions would be cool. I did get the seal that goes around the shaft for the park jam lever thing's shaft and it was in perfect condition, so I'll see if that should be replaced too. Also, should I use a urethane o-ring? I'd think a buna o-ring might swell a lot, or do I want that? If it swells too much it won't seal right. Thanks.
My FSJ pics
FSJ Grille Identification
Old 11-08-2006, 10:10 AM
710 Burner's Avatar
IIRC it is an actual seal.
Mark B. Jones
Old 11-08-2006, 10:33 AM
You need to use the correct tool, and the correct seal.
Otherwise you're just wasting your time.
Old 11-08-2006, 03:44 PM
DanHS's Avatar
So it's an actual molded seal and not an o-ring, wonderful, that will make finding it harder . Nobody can get that stupid tool either, not even the car parts place that can get other KD tools. That figures. I'll have to order it online.
My FSJ pics
