Old 04-15-2005, 01:43 PM
JP
Posts: n/a
Red face
I'm putting on a BJ's lift - awesome product, great service, thanks Brent! - anyway, the driver side bottom rear shackle bolt is completely rusted to the bushing. I've been hitting it with PB Blaster for a week before starting. I've tried heat (MAPP). It moved about 3/16" inch and now I can't even get it back where it started. It appears that I can't even cut the bolt out because of the bracket it's in. The good news is the captive nut didn't break when I pulled that bolt so I'm considering myself fortunate [img]smile.gif[/img]
Anyway, besides PB and heat any tricks I'm missing? It's too bad I can't just remove the top bolt as it's loose as a goose...
Old 04-15-2005, 02:34 PM
Ok, JP, as I understand this it's the rear bolt, left (drivers side) at the box in the back?
I suggest (you may have tried this) a big pair of vise grips locked on tight and a pry bar.
I assume the nut came off and it's frozen in the bushing?
If it will move back and forth, then it will come out eventually.
Beat it back and forth, in and out, keep soaking and prying.
Loosen up that crud in there enough and it will come out.
Old 04-15-2005, 02:36 PM
Bandit-CO-
Posts: n/a
I had the same problem on my J20. I just kept hammering, prying and PB Blasting. It took a couple of days but it finally came out.
Old 04-16-2005, 01:57 AM
JP
Posts: n/a
That is the bolt in question. I hit it with PB again this morning. I guess I know what I'll be doing today! Thanks guys.
Old 04-16-2005, 02:36 AM
mudslider's Avatar
mudslider mudslider is offline
i agree with turning and tapping at the same time if you can.
P.J
Stupidity rules at all times! Famous last words "Hey, watch this" Its 5:00 Somewhere. 1983 J10 In process: 360 ci install
Old 04-16-2005, 03:31 PM
Well, we did beloth's this morning here.
The front, so this is not really applicable.
Right side took a sawzall to get off, got lucky on the left.
Cut the right bushing bolt on each side, dropped out like a baby (not sure how that works for your rear box hanger).
It's a tough cut to say the least.
Old 04-17-2005, 11:32 AM
beloth's Avatar
beloth beloth is offline
Thankyou very much for that time on Saturday tad.
It rides awesome and looks 200% better than before.
I appreciate your time thanks again..
Robert
1966 wag "JENNY" w/1973 drivetrain
330K miles w/360 V8 2bbl (HEI installed ), flowmaster muffler
TH400 /Dana 20 transfer case D30 /D44 w/ 3.73's LT235/75/R15 AT tires. lift shackles in frt. 2 in lft; w/ TAD's Dozer bumpers! Cost $700 -now total cost=?
Old 04-17-2005, 01:07 PM
worn4wd worn4wd is offline
i push out the tuff ones with my balljoint press....the weak shall perrish.
Old 04-17-2005, 01:27 PM
Robert
Robert, you are always welcome at my place.
That's how it supposed to work.
People, help people, nothing to gain, nothing to loose.
It's a pretty simple concept that results in some very good Karma.
I prefer it that way.
Old 04-17-2005, 01:40 PM
youngjeeper's Avatar
youngjeeper youngjeeper is offline
yup ive sawzalled mine out before. those things can be a PITA
88' GW Stock & Mint
77' CJ-7
http://gfsj.org/forums
Choptop/Crew Cab Build-up
http://www.ifsja.org/forums/vb/showthread.php?t=93389
Old 04-18-2005, 03:01 AM
Poley's Avatar
Poley Poley is offline
pound and pound turn and turn and repeat.. heat and PB work it takes awhile
Fullsized Gets it DONE!!!!
Old 04-18-2005, 03:19 AM
JP
Posts: n/a
Well, the bolt came out on Sat. It seemed that heat was the key. Anyone know the flash point of PB blaster? It sure seems to penetrate well when the bolt is hot! Anyway, lots of blaster, heat tapping and turning and it came out. One other was rusted in on the front main eye, but I could get to that one and pressed it out...with heat and PB...
Thanks for the advice.
