Old 03-21-2005, 05:09 AM
viscacha's Avatar
viscacha viscacha is offline
Cool
For you fabricators…
I finished my spring plates for my Dana 60HP this weekend and they came out pretty well. I used my original 19 year-old sway bar mounts and some 40 year-old ½” hot roll plate from the mountain that use to be a state-of –the-art telescope in its day. Then I welded some ¼” crs spacers underneath to compensate for the 3” wide spring perches to 2 ½” springs. The final product is a tightly fitting spring plate without any slop as are the original plates used on our rigs. There are no oversize holes for the u-bolts and no gaps between the springs and the u-bolts. The location of the sway bar mount is within ½” of the original location. They are untested but appear to have no interference with high steer components and the sway bar can be disconnected with standard disconnects or custom ones. I did check the strength of the sway bar mount and found no bending with 1200psi of force applied so I don’t think a 525lb axle will deform them. They are intended to be used on road only.
steve
’86 J20
SOA, Dana 60's, F/R Lockers
Full High Steer, Ram Assist
Bunch of Other Stuff
Old 03-21-2005, 06:28 AM
FSJeeper FSJeeper is offline
King of Unfinished Projects
Nice fabbing!
Old 03-21-2005, 06:57 AM
Very Nice Steve.
Old 03-21-2005, 07:30 AM
rockcandy rockcandy is offline
sweet! That seems like a simple yet strong solution to those needing the swaybar for street use.
1979 waggy, one ton WT conversion going on...
1979 golden eagle buggy...living on through donations across the country
Old 03-21-2005, 09:26 AM
nice fab steve!!!
Todd
www.ttsfabworks.com
Old 03-21-2005, 11:16 AM
Stuka's Avatar
Stuka Stuka is offline
Nice. Are those custom leaf packs? I dont think I have seen 8 leaf spring packs up front before.
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 03-21-2005, 11:17 AM
JeepsAndGuns's Avatar
Verry nice work. I like how you did that, real slick. How did you end up mounting the u bolts on the drivers side, it looks to be some kind of spacer under the ubolt to let it go around the rib cast into the housing. I would like to see how you did that too.
Old 03-21-2005, 02:55 PM
viscacha's Avatar
Cool
The front springs are stock J20 with a long add a leaf under the spring. You can see in the pic how they protect the eye of the spring, I sort of like that. That’s the current configuration. I’ve had them in and out and had the spring packs down to four leafs to get a really flat spring so I can have some info later on for custom springs.
I made a u-bolt sleeve to prevent notching completely through the rib. The sleeve mates with a square notch ground in the rib part way. That way the sleeve is trapped and can’t rotate or slide. The sleeve is welded in place and the u-bolt is trapped in a groove.
steve
’86 J20
Old 03-22-2005, 02:39 AM
Zac Zac is offline
looks awesome
what tools did you make that u bolt sleeve with?
Zac
82 Wagoneer<br />welded 44 and detroited 14blt<br />np 208<br />rebuilt 360 36/12.50 tsl<br /><br />Thing is man, I don\'t even care.
Old 03-22-2005, 03:32 AM
Jeep Doctor
Wow! Those swaybar mounts are NOT going anywhere, are they.
Old 03-22-2005, 05:58 AM
viscacha's Avatar
Originally posted by Zac:
looks awesome
Zac
That’s a pic of the final design. I machined the outer diameter and groove on a lathe and then cnc machined the center to match the contour of the diff casting. Unfortunately the contour of the diff casting is neither a true circle or concentric with the axis of the tubes so it can’t be finished on the lathe. It is a arc-spline that roughly forms a tear drop shape with an axis above the axis of the tubes. I roughed a 2.50” diameter hole in the center of the part with the lathe before final machining on the cnc. Each lathe part makes two sleeves.
You could make this sleeve with a piece of round stock and a hand grinder. I made a prototype on the lathe and then used a hand grinder to match the contour of the casting and beveling the edges as needed for the radius in the casting. Once I had the prototype fitted I modeled the final design and then used a cnc milling machine. The two holes in the sleeve are tooling holes for fixturing.
steve
’86 J20
Old 03-22-2005, 06:09 AM
AMX factor's Avatar
AMX factor AMX factor is offline
You should sell those u bolt cradles. I'd be interested. I'm gearing up for a Dana 60 conversion. If interested shoot me a price.
"I'm sick of this sickness, don't touch me you'll get this."
1984 GWag "orphan" for sale
2 x 1975 Matador "murder machines"
1970 SST390 Javelin 10 yr project!
Old 03-22-2005, 02:09 PM
Yes! me too, I would be interested in one too!
Old 03-23-2005, 04:38 AM
FullsizeWagon FullsizeWagon is offline
That's one of the cleanest u-bolt setups I have seen. Cheers to you. And yah, you should manufacture those things!
Old 03-23-2005, 05:50 PM
TireFryerSS TireFryerSS is offline
Looks like I just found someone to help me do all the suspension stuff on my Waggy!
Old 03-24-2005, 02:52 AM
viscacha's Avatar
Cool
Well, I don’t have much time to make parts these days. I have just a couple weeks here and there before I have to go work on the mountain again and then I don’t have a home life. I’m glad to help out if I can, though.
All my designs are available in pdf free of charge and should only be used for educational purposes.
Here’s a pic of my offset shims for the rear axle.
steve
’86 J20
Old 03-24-2005, 05:20 AM
Steve, I'm gonna puke now. That is just so darn precise looking.
Congratulations, it's awesome.
